Question about Intermatic Inc. ST01C Digital In-Wall Timer
Even with new battery, on-off will not click - Intermatic Inc. ST01C Digital In-Wall Timer
1) If timer worked before and stopped working, then manual says last step is to reset timer.
If timer will not function after reset, then timer is broken.
2) You posted under battery-operated ST01C timer, that comes with 1 year limited warranty.
Open following page to identify timer, read ez instructions, and download on-line manual
http://waterheatertimer.org/ST01C-program.html
3) How to reset ST01C
Hold down on-off button and press reset button
Release reset button.
Keep holding down on-off button until INIT flashes on screen.
Release on-off and 12:00 will flash
Re-program timer using ez steps shown on link above.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 13, 2011
Starter clicks when I hit starter button
Assuming that the battery is good (even new ones can be bad) it sounds like you have either a bad starter solenoid or bad starter.
Jul 26, 2016 | Cars & Trucks
My 2004 nissan maxima wont start or say anything even with a new battery!!
The starter doesn't spin? Do you hear a click (when you try to start the engine) from the starter area maybe?
Jun 24, 2016 | 2004 Nissan Maxima 3.5 SL
Replaced starter new battery fuel and air filters blown fuses wont start only click click
'Click Click' means not enough electricity is making it to the starter. This could be bad or dirty connections, a bad starter relay, a weak battery (even if new), bad electrical leads, a misaligned starter (jammed bendix or bad flywheel)...
Sometime DIY means do it again....and again...and again, until you get it right(ish)
Apr 02, 2015 | Cars & Trucks
Bought a new battery it wont even turn over to start
If you get a clicking sound, that means the solenoid is working. Check all connections for corrosion and clean if necessary. Did you check the engine to frame ground wire? If all connections are good and solenoid clicks then the starter is more than likely bad. Did you do a load test on the new battery. It is possible to get a battery that is bad due to excess lead dropping into the battery case when being made.
May 03, 2014 | Garden
The battery is brand new and when hook it up and turn the key the neutral light and the hot light come on but when I hit the start button it clicks and doesn't click anymore. Not even turning over. Th
Remove battery terminals and clean both posts and terminals
with sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to current flow both into and out of the battery. Charge the battery as not all batteries are charged sufficiently when new to do the job. Also not all new batteries are good batteries as they suffer manufacturing faults which allow them to discharge internally. some batteries are sold without the acid so check that is not the case.. Check all terminal connections including any earth wires.
Jul 15, 2013 | ATVs
Car won't start. New battery installed recently. Only clicks when trying to start.
one single click any time you turn the key usually indicates a bad solenoid on the starter. A new starter will typical get you going.
A series of rapid clicks when you try to start usually indicates a weak battery. There could also be a bad connection at the terminals on the battery or even a poor connection at the starter.
If you get a single click and everything goes dead for a couple of seconds than you definitely have a bad connection at the battery.
Let me know what you find or if you have any questions.
Dec 28, 2011 | 2007 Chevrolet Tahoe
06 pontiac grand prix wont start no clicking when you turn the key over even jump starting the battery, has dash lights & radio & parking lights. battery tested good. put a used starter & altinator on
Used parts such as starters and altinators don't last. It might **** but it sounds like you need to buy a new starter,altinator, and battery. Or just start with buying one at a time.
Dec 06, 2011 | 2006 Pontiac Grand Prix
Car wont start. power to accessories. wont turn over. wont even click. new battery ad new starter. any ideas?
If you not even have a click this narrows it down to only a couple of areas. Most likely it is a ground issue. I for sure would really check your cable and connection from your battery. The hot lead and more importantly the ground that goes to the frame. If it is not clean and grounded real good, you will not even get a click. if you turn key on and hear nothing, it is for sure the connections from battery to ignition. Now, if you can turn on head lights and all that, that mean your getting power to your ignintion and battery is good, now what this means is the connections from your starter that go to the battery are not good. Check those real good. I am almost positive this is going to be a connection problem of starter and battery. keep me posted MIke
Oct 01, 2011 | Cars & Trucks
The car won't start, not even a click. I put a
Check your battery an eas way to know if its compleatly dead is to see if the lights come on or radio, you probley need a new alternater if the battery is dead again .
Jan 26, 2010 | 2001 Kia Sportage
Intermatic Inc. ST01C Digital In-Wall Timer Logo
69 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
