Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
Acer 4520 unable to read the CD DVD ROM drive. When it is starting it does detect it, but after it enters Windows it doesn t even show up on the Device Manager. Actions taken: Restore windows Reviewed hardware, it is ok Upgraded BIOS Deleted REG KEYS
  • Acer Master
  • 27,725 Answers
Click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected hope this helps don
Posted on Mar 13, 2011
Acer aspire 4520 windows 7 CD ROM Drives
If your asking which driver you would need for your CD Drive. The answer is you don't need a special driver for it. If it's not working then you could try cleaning the laser lens with a CD laser lens cleaning kit. If that doesn't work then you need to replace the CD drive.
May 30, 2012 | Computers & Internet
Hi, i have problem with my acer aspire 4520. sound card not detect but some time detect. dvd-room not detect. please help me. thank's you
For the sound card issue, try resetting the default BIOS settings, the re-installing the sound card driver from Acer's website
for the DVD issue try re-seating the drive then run this tool
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Jul 05, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have just installed a fresh copy of windows 7 on my aspire 5738G and after the instalation was complete the PC doesnt detect the cd/dvd rom anymore. It doesnt even show in My Computer. I have the latest...
If you have installed the chipset driver, you could locate the producer of the CD/DVD ROM, and check if there is drivers to download from their homepage.
Jun 04, 2011 | Acer Aspire 4520-5582 Notebook
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
My cd/dvd drive is unable to detect any cd/dvd.acer aspire 4520
I do have the same problem, my laptop doesnt detects the DVD writer, checked with the acer support, asked me to check the motherboard and may need to change that.
Jan 31, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
ACER LAPTOP NOT STARTING
Try to reinstall windows overwriting the previous installation so that all your data, files and programs will not be deleted. If you have your windows installation cd, insert it to the cd/dvd drive and start/restart your laptop. It then detects the installer and scans your computer. Just follow the on-screen instructions. But during setup, do not choose the "Repair Mode" instead choose "New Install". Now when attempting to install, then system will detect your previous windows installation so there highlight (using the arrow keys) choose "Repair Previous Installation". When you do this, all windows system files will be replaced but all programs and personal files will be in tact.
Dec 29, 2009 | Acer Aspire 4520-5141 Notebook
I connot open the windows.windows showing NTLDR
this could be the computer trying to boot off a USB device plugged into the computer.Check that you don't have any USB devices plugged in. and no CD in the drive. then reboot the computer.
Dec 09, 2009 | Acer Aspire One PC Notebook
PC will not read CD's on DVD drives
my acer 4520 cd rom is not working well when i press cd roms butten its not *** out & also in my computer its tht cd rom icon is not showing so plz give me the solution asap....
Jun 23, 2009 | Acer (91.AB264.001) CD-ROM Drive
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My acer aspire4520 laptop is unable to detect my removable cd/dvd drive
You will need to install chipset driver but it will be much better if you reinstall all driver for it.
Acer Aspire 4520 driver for windows xp can be downloaded here :
http://www.drivercabinet.com/driver-acer-aspire-4520-windows-xp/
Nov 01, 2008 | Acer Aspire 4520-5582 Notebook
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
