Question about LG Dryers
The heat vent on my LG front load energy efficient clothes dryer is some what rusted looking and putting off a burnt odor. What do I need to do?
    President:
  • 3,074 Answers
I would say take it apart and clean it out, as lint does get inside the dryer and some times next to the heating element, hope this helped Tim
Posted on Mar 13, 2011
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
Taking a long to time to dry doesn.t get very hot
Igreat answer above now here is a great video shows how it works and what to check
Jan 04, 2011 | Dryers
Why are the clothes coming out of the dryer smelling musty? we have the lg tromm dle5977w
The problem might not be with the dryer, but with the washer. Let me explain. When I first got my LG w/d set, I did a web search, and found that front load washers tend to build up bacteria and mold(which one person said was staining her clothes). The solution was to leave the door of the washer open when not in use. That worked for me for the most part, but the musty smell persisted. I found that the soap tray was getting dirty(from mold/bacteria), and the area inside was even worse. So now I remove the soap tray when not using the washer. Also, some appliance stores have cleaning packs that dissolve in an empty washer load. They are supposed to clean out residue and kill bacteria that cause odor in "HE" washers that may only be noticeable from the dryer. The brand name of the product I have is "Washer Fresh", and they're about $12 for 6 "PowerPacs".
May 06, 2010 | LG DLE2514 Electric Dryer
1. ) not heating up / cleaned heating sensors mounted on the lint vent holder with ALCOHOL last week ....we had an ink pen in the load ...since then /subsequentially its not heating up...? could that...
If you use a flashlight and look down the filter housing you may be able to see the scock and remove it with a coat hanger.
Rotate the drum both ways with you hand while looking if you cant see it.
Dont worry about the sensors they are ok.
No heat?
May be several things...
Plugged vent
Bad ignitor
Bad gas valve coils
Bad main pcb.
Jan 18, 2010 | LG DLG3788W Gas Dryer
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
My dryer makes my clothes stink
You NEED to have a professional vent company clean your dryer out! PLEASE don't run your dryer when you're alseep or not at home due to a fire hazard! It sounds like the dryer is full of lint that's buring and make sure you clean your lint filter EVERY time you dry a load for safety's sake and energy efficiency.
Aug 14, 2009 | Dryers
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
243 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
