Question about RCA Televison & Video
When programming my remote to the tv. Somehow I wiped out the cable. There are no directions on how to setup the channels again. When I go to the menu button it does not list anything at all. I have tried everything. But I don't know the correct sequence to get my channels back.
  • tonrob13 Mar 13, 2011
    What is the remote?
  • latkins1481 Mar 13, 2011
    RCA number RCR312WR universal remote
  • 23 Answers
How do I switch the TV from cable to regular TV
Depending on your TV make, normally hitting the antenna button will switch you from cable to antenna (regular) TV.
Aug 24, 2015 | Video Game Consoles & Games
How to reporgram my tV's remote to the Tv again
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 09, 2012 | RCA Televison & Video
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I hve a philipf sru3006 need code for my tv Symphonic
You can download the manual from
http://www.retrevo.com/d/ds/progress?doc=d74782ab23218f4c972a807a9afa3fc7&rk=0.15356064987977386
To manually program your unit,
controlled.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Aug 14, 2010 | Philips SRU3006 Remote Control
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Lost directions and code for setup
Here's how:
Turn on the electronic you will programming the code for.
Press and hold the CODE SEARCH button until the red indicator stays on, then release the COE SEARCH button.
Press and RELEASE the desired mode button (TV, VCR, etc.). The red indicator blinks quickly, then stays lit.
Enter the 3 digit code from the code tables.
With the device on, press CHANNEL UP on your remote. If the device responds, no further programming is required.
(I have the code chart, if you tell me what components you have, ie reply to this post, I will give you the proper codes.)
Nov 05, 2007 | Philips PM4S Remote Control
Televison & Video Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
