Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I had my mower sitting on an Incline while turned off. When I started it again, after about 2 hrs, the forward and reverse make a grinding noise and do not work, the wheels are locked, even when I have the manual push stem pulled out. my machine is a LTX 1045. Rmccaffrey@mesadesigngroup.com
  • 3 more comments
  • rmccaffrey Mar 13, 2011
    I have pulled it to level ground...will wait until morning...with low fluid, the wheels would be locked?....as I pulled it to a level place, I had to drag the fixed rear wheels.
    The manual says that the hydrostatic transmission ismsealed at the factory, fluid can not be checked or changed. How do I address this...where is fill point for transmission?
    The premium answer I received regarding my Cub Cadet LTX1450 suggested that I replenish the hydrostatic transmission fluid in order to unlock my drive wheels...my owner's manual states that the hydrostatic reservoir is factory sealed and can not be checked or filled. The rear wheels are locked in place and when I press the forward or reverse pedal, there is a grinding noise...no movement. There has been no trauma or event with my machine...it only has 18 hrs on it...this happened after sitting on about a 15% incline for about 2 hrs.
  • rmccaffrey Mar 14, 2011
    I followed the second recommendation and took it to the dealer. It seems that the problem is in the factory sealed hydrostatoic. My machine only has 11 hrs on it. Thank you for you suggestions.
  • 5,370 Answers
Yes you are correct:---- This type of transmission is sealed and does not have a hydrostatic fluid fill or drain plug. Have your Cub Cadet tractor serviced by a trained technician if you experience problems with the hydrostatic transmission.The transmission assembly needs to be disassembled and inspected.--------------
Make sure the belt is in the groove of all of the pulleys. They are good about coming off the pulley on top of the transmission.
Pulling of the released wire allows the transmission fluid to drain within the transmission so that the tractor can be pushed.
--------- If the belt is on correctly and is not off of any of the pulleys, and the lever that you pull out to disengage the transmission is working correctly then you have internal transmission problems. Make sure when you move the lever to engage it that it is connected to the lever on the transmission and that it is moving. ---------- This should help.Keep updated.Thanks.Helpmech.
Posted on Mar 13, 2011
  • raj somaiya Mar 14, 2011
    In that case check the park brake caliper and lock.If they are blocked/jammed or seized.
    Try to release it and it should move freely.Give a gentle whack from a persuader to get it to come free if its very hard.--------Check out.Keep updated.Thanks.
  • 643 Answers
The reason for this issue is the hydrolic fluid drained from the cylinders and you need to check the fluid level, refill and you will have to work the handles until it refills the cylinders.
  • 10,865 Answers
Hello rmc... these mowers have a hydrostatic transmission which rely on transmission fluid to operate.
Get your mower sitting on the level and leave it for a couple of hours and then check the transmission level. If it is low, add fluid. Always keep these mowers transmission fluid slightly over full for best performance of the transmission. Joe
Thanks for choosing Fixya!
Today while cutting my lawn my mower started making a loud grinding noise and will not go forward or reverse when I press f or r pedal
this is not good . probably already to late to save the transmission. Haul it to a dealer .
Sep 17, 2015 | Garden
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Won't drive in reverse
Failed Transmission Again
Part with it
Get something else
Maybe American (Rear Wheel Drive Only)
Dec 12, 2012 | 2001 Mazda Tribute
What is it when in reverse the automatic transmission on a 1999 Camaro grinds?
Reverse is not "synchronized" forward gears are, so it does make some noise, try shifting to 2nd before engaging reverse to slow gear rotation and limit gear clash or grind.
Oct 08, 2012 | 1999 Chevrolet Camaro
My 2003 Ford Focus started making a grinding noise when in reverse and in right turns. After driving about 20 miles the symptoms disappeared. The symptoms have gotten progressively worse, vibration and...
Check the front engine mount..If its bad it could make a noise while turning or reverse..Hold the car in gear with your foot on the brake and carefully raise the engine ..do it in both reverse or forward and look for excessive movement..
Sep 22, 2011 | 2003 Ford Focus
Need hydro drive wheel right side for craftsman zt7000
its a zt7000 craftsman homeowners sit down 0 turn mower.mower is made by simplicity 18 hrs koler. since i last posted i had a freind who works on hydro motors for a living break it down clean it and look for visual damage. there was none so it was put back to gether. new gasketts and lubed. after assembly neither side work at all now and makes a grinding noise when levers are put in reverse. left side worked before right side was taken out, left side was never touched. resovours were filled and everything was put back together correctly im positive. im at a loss with this.
Nov 01, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Grinding noise when backing up Jeep Liberty'06 only in the AM..
Have your rear brakes checked. It might be a brake wear indicator. Or your rear brakes are stuck on the brake drum.
Jul 09, 2009 | 1999 Dodge Durango
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
361 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
