Question about Garden
Have put straight fuel in Echo Hedgecutter is there anything I can do, it actually stopped working
    President:
  • 1,082 Answers
You failed to use oil in mix for a 2 stroke engine. Engine seized up?
You might get lucky . Allow it cool down all the way.. Drain the fuel out.
Remove the spark plug and put several drops of straight oil in the cylinder.
Let the oil soak for a while 20 - 30 mins.. Pull on the starter to cycle the piston, watch for spray from open plug hole, put a towel over it first.
If you're lucky it will free up and run some more even with scored cylinder walls. Though the overall life of the engine will be shorter.
Put the plug back and correct fuel mix and try to fire it up. Good luck.
Posted on Mar 13, 2011
  • hjv001 Mar 13, 2011
    I will certainly give this a try...many thanks
    Master:
  • 403 Answers
Does it turn over at all, if not try pulling the head cover off and giving the top of the piston a few raps with a piece of wood and a hammer. Hopefully you didnt sieze it up completely.
    It has completely seized up so I will give this a try ...many thanks
I put just gas in my echo Es 250 ! Can it be fixed?
Hi did U run it with straight petrol or do U just want to change the petrol to 2 stroke fuel.. Cheers
Nov 20, 2016 | Garden
Why is my 2000 Toyota Echo misfiring on left turns ?
Sounds like you have a wire in the steering column that is shorting when you turn left but goes back to close to normal when you turn back to straight. Check the wiring harness coming out of the steering column.
Aug 14, 2014 | 2000 Toyota ECHO
Echo ppf-210 power pruner will not stay running? I have changed the plug, rebuilt the whole carb, new gas, etc. Still will not stay running? It will idle a small bit and as I pull the throttle I get no...
check the fuel filter to see if its dirty or not under fuel . also you will have to re-tune the carb . or check for compression in the engine it should be at 120 or above you may also want to change the plug
Sep 26, 2013 | Echo POWER PRUNER
Echo hegdecutter
Ouch it does sound like your gears are gone. Take it apart, few screws, much cheaper to buy the replacement parts.
May 26, 2013 | Garden
My Echo Blower Model: PB 755 T was working fine I stopped it to put more gas and now it won't start,
spray carb clean in the carb, just a shot with throttle all the way open then try starting, If it fires then you have a fuel problem,like maybe the filter in tank dirty or dirt made it to carb or needle valve is stuck in carb.
Apr 02, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
2001 Echo stalls when coming to a stop at stoplights etc. The Dealer could not replicate the problem, however it continues to happen.
this could be a fews things...Bad fuel or water in tank.. Replace fuel filter and put some high octane boost in the tank and fill up with 93 octane. You may need a tune up
Nov 03, 2010 | 2001 Toyota Echo
My 2002 Toyota echo was working fine. I didn't
could be anything from the fuel pump to the immobilisor ,you will need to start checking it over
Apr 03, 2010 | 2002 Toyota ECHO
Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Apr 04, 2009 | Echo Garden
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
