Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Well, I was attempting to replace my speed lever. In the process I removed the back cap (electrical circuit board) and the two screws on the side (flat, springs with magnets attached). After I replaced what I took off ...my mixer will not start.
I re-adjusted the springs/carbon and it still won't turn on. That's the only thing I did so not sure why it won't turn on. Help?? Thanks
Posted on Aug 15, 2014
  • Becki M Sep 27, 2014
    Justin, made sure thhere correctly and it still won't turn on. Any other suggestions?
    Guru:
  • 257 Answers
Hello Lora,
I understand that you took you speed lever out to replace it and you took the brushes out of each side of the unit. The reason that the unit will not start is more than like the brushes are not installed the proper direction.
1. Unplug the machine
2. Shine a light in the hole on the hole on the side of the unit. You will notice a notch or a piece sticking out.
3. Take one of the brushes (magnet looking things) put the notch and the cut out in the same corner.
4. Repeat the samething with the other side.
5. Plug in and check and see if it runs
This should solve your problem with the brushes. IF you have any more questions about this mixer please post it to this discussion.
THank you for choosing FixYa.com
Justin
Posted on Mar 13, 2011
Ksm 103 on one speed
Remove the back cap over the speed control and look at the speed control plate while operating the speed lever. Make sure the lever is moving the plate in and out. If yes then I would replace the small PCB above the control plate, that is the electronic part of the speed control and not worth very much at all.
Jun 15, 2016 | KitchenAid Food Mixers
How do I replace the speed control lever on a kitchenAid artisan mixer
Remove back cap, remove white wire and black wire from lower corner of speed control plate, both on same side on adjacent terminals. Remove the gasket thing at the back as well.
Remove chrome drip ring from around planetary, knock pin out of planetary and remove the planetary.
Flip upside down on a towel and remove pedestal by taking out hinge pin (1 locking screw from underneath inside pedestal)
Remove all screws from bottom side of gearcase, 5 around planetaty, 2 in the middle and 2 at the back.
You can now seaparate the gearcases to get to the speed control lever which is held on by 1 screw.
Feb 15, 2015 | KitchenAid KSM150PS Artisan Series Stand...
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
How do i split the case
Chrome drip ring off, knock pin out of planetary, remove planetary, back cover off, black wire and white wire off the control board (both on the same side at the bottom) undo 5 screws under planetary, undo 4 screws remaining in housing underside. Split cases.
Jan 18, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid KSM150PSOB speed switch will spring back to 3rd speed setting when trying to turn off. Noticed when its off and a little downward pressure is applied to the switch, it'll spring. Attempted to...
It probably is the worm gear but you must remove the planetary roll pin to be able to split the gearcase. You will find another smaller roll pin in the worm gear. Your speed lever problem will be either a loose screw that it pivots on or the lever is bent. Hammer and correct size punch is only solution for those roll pins. Bigger hammer sometimes helps.
Sep 15, 2013 | KitchenAid Food Mixers
Mixer only moves at one speed
Referring to the following parts description:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
The speed is controlled with a combination of the governor assembly #24 which mounts on the motor shaft, and the phase control board #27 which is mounted on the back of the mixer.
They operate in conjunction with item #25, the control plate assembly.
WARNING SHOCK HAZARD. FOLLOW THESE STEPS ONLY IF YOU ARE COMPETENT WORKING AROUND HOT ELECTRICAL COMPONENTS AND FOLLOW ALL SAFETY PRECAUTIONS!!!
Remove the rear cover screw #37 and the rear cover #36 and examine the governor when it is running. Also watch the speed control lever mechanism as you move it from off to the highest speed watching for binding etc.
Make sure that the spring #4 is attached to the bottom of the control plate #25.
If the governor appears to be opening and closing as the speed increases and the linkage is not binding then the problem is most likely the Phase Control Board, item #27.
Apr 19, 2010 | KitchenAid K45SS Classic Stand Mixer
I need help in correctly reassembling my Kitchenaid KSM 150 mixer. I used the help on the web to successfully take apart, clean and regrease my mixer. However, I have not yet been able to successfully...
First dissconnect the power supply.Next, the locking hook must be facing towards the back of the unit. However the lever itself must be placed inside the bottom portion of the unit going out to the side. Next you need to connect the metal link to the lever and UNDERNEATH the locking hook. Once you have done this you can now put the screw in to hold down the lever. Your one speed problem could be caused by the adjustment screws that are connected to the main board at the bottom. if these are not set correctly and most importantly EVENLY the mixer wont operate correctly. The next possible solution is that the main control board is faulty and would have to be replaced part number for the board is w10119326. Also I have added this link from Whirlpool that you can use. Hope this helps. Thanks
http://www.whirlpoolparts.ca/parts/fspShow.php?model=KSM150PSWH0
Nov 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kichenaid Mixer K5SS Electrical Problem - All gears have been removed. Motor shaft turns easily. With speed lever in off position, 0 volts go to motor via red and white wires. With lever in any other speed...
I had this problem also: power to the motor, motor not running.
Solution was simple: remove the 2 stators things from the sides of the main housing, clean all the black dust off them, re-insert and everything works fine.
The dust problem is similar to model train sets that I had as a kid at Christmas, the black dust acts as an insulator, preventing power from travelling between two metal parts that you'd think otherwise would conduct.
Aug 26, 2009 | KitchenAid Food Mixers
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
Mixer just won't turn on -speed control jammed
Unplug the appliance. Take it to a well ventilated area and spray some alcohol in the slot where the switch is while trying to move it. This must be done with the appliance unplugged and the appliance must be thourughly dry when you plug it in. Use canned air or if you have one a compressor.
Mar 05, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
214 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
