HI, I have a sony BRAVIA TV model KDL-40S2530 never connect on any antenna (so no update possible). The power PCB is G2A ... and after 1/2 H, the tv power off - on - off -on like a metronome. After downloding the schematic, I have done some test and it's the 18 V than, after 1/2 H go down to 12V ... so the relay switch off, and on ... and the 18 V go up .... and down ... etc ... I suspect IC6100 .... Thanks for answer Best Regards CM
    Problem Solver:
  • 13 Answers
Check the (1-873-818-12) DF4 board part IC6704 see if pins 1 and 3 are dead short ...ps i would like to know ware you got the schematic as i would like to have a copy as well carl69jr@hotmail.com
Posted on Sep 15, 2011
  • 718 Answers
I sounds like heat might be a factor.
You can get a can of circuit cooler and spray the ic and see if it works longer.
You can test the IC6100 by looking at the input and output. If the input voltage is in specs and the output falls then IC6100 may be at fault. If you have an oscilloscope with two probes you can see it in real time.
You can get a similar action with bad electrolytic capacitors which will eventually fail. You can replace the electrolytic capacitors with low ESR high temperature one.
Posted on Mar 13, 2011
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
My Sony KDL 4040W4100 Keeps turning off and then turns back on again durning a show... what is the problem?
These trouble is commonly caused by a rusty or dirty switch. It is easily to determine what switch, try to check the power switch or replace a new one. When replacing a switch open the back cover of your tv, try to locate the power switch by looking for the power button, It is connected in a small pcb together with the volume and channel button it is separated to the main pcb connected with a wire.
May 28, 2011 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
Hi got sony bravia 40s2530 40 inch tv,woz workin fine but wen turned bac on came on 4 a few seconds then red flashing light 4 flash then 3 sec brk & 4 flash again & so on!any ideas?
You can fix this yourself , having basic knowledge on electronics will make it easy but not withstanding you can get it a try.
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care and this help in solving the problem
Sep 13, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Lightning strike to a Sony Bravia KDL-37m4000
Check if all the PCB board intack.Might worth repairing.
Sep 10, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
