Question about YouTube Videos
Videos download about 3 seconds then stop for 1 or 2 minutes. most of the time it fails to complet the video.
    Sniper:
  • 118 Answers
It sounds like you have a bit of a dodgy internet connection. Try using an ethernet cable or change the graphic setting of the video to a lower setting (720p to 360p for example).
Posted on Mar 13, 2011
On my Samsung Galaxy note 3 suddenly when I play a you tube video after a minute the picture freezes but the sound continues to play! Any suggestions how to fix this please?
Having same issue on my Note 3 recently on every video on YouTube. Video stop playing every 20-30 seconds but audio keep going. I have to touch position slider every time to make video playing again. Happens multiple time for each video. My friend suggested me to go for Mobile phone repairs
Samsung Galaxy Note 3
Nov 19, 2014 | Cell Phones
Why does my hp w2558hc widescreen lcd monitor goes out intermittently?
Lots of possibilities. Bad cable. Failing monitor inverter (converts AC from your house wiring to DC used by the monitor's internal components). Loose, corroded or dirty connections. Failing computer video card (not common, but possible). I would: 1. Check all connections, and plug/unplug cables several times, then ensure all plugs are firmly seated and tighten the screws (VGA or DVI only). 2. Test it with a different cable, preferably one which is known to have no issues. 3. Test it with different video types (I have an HDMI cable that will intermittently go out for 1-3 seconds, every 3-4 minutes, if I am streaming video from the Internet to my 42" LCD, but almost never does it when I am working with mostly static images). The cable is the cheapest component to replace, so I would suggest debugging it very thoroughly before moving on to much more expensive solutions (e.g., video card, monitor repair). Hope this helps you narrow it down.
Jul 12, 2014 | HP Computers & Internet
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
Downloaded youtube video and got failed to load message
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General video", then select an MP4 format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP4, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No Adware. Do not hesitate. Have a try!
Mar 01, 2011 | Applian Technologies Freecorder Toolbar
I cannot play videos on UTube with my IPad. The videos stop every few seconds as if they are reloading . am I doing something wrong or is it because of the"NO Flash" issue with Apple?
It could be the speed (or lack of it) of your Internet connection -- you cannot download fast-enough to provide "real-time" video. When you start to download a video, press PAUSE, and let the download continue for a minute or two. Then, click PLAY, to view the already-downloaded stream.
Nov 30, 2010 | Computers & Internet
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Why wont my pc play youtube music videos
1. bandwith
2. busy youtube site
3. congestion on the video itself (lots of people watching)
Solution:
www.veoh.com like youtube but much faster.
Download the video directly on your computer using real plyaer video downloader and watch it that way. Or subscribe to a hgigh bandwith package or wait during non peak times.
other possiable cuases are:
Adobe flash needs to be updated. www.adobe.com
you can also try html 5 @ www.youtube.com/html5
Good luck
Please before you leave, please leave some feedback and ratings. Thanks
Apr 13, 2010 | YouTube Videos
Video Stops Early
http://www.microsoft.com/hardware/digitalcommunication/productdetails.aspx?pid=007.Everything you need is here.this is a solution.when you vote if this worked vote blue ty.RICHARDM69
Dec 15, 2008 | Microsoft LifeCam VX-3000 Web Camera
Failed creating file
I had to re-do the project, this time using Standard Quality rather than High Quality, and it completed creating the file(s) and writing the DVD.
Bernie
Mar 26, 2008 | Panasonic Palmcorder SDR-H18 Camcorder
YouTube Videos Logo
43 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
