Question about Ovens
I have a magic chef electric smooth top range. everything works fine, but f-1 keeps appearing with the noisy beep beep beep. Press clear and it gets quiet for about a minute, then starts again! Only way to make it stop is to turn on bake or broil right after pressing clear. What do I need to do? model # 3888XRB serial # 17C343465951 . Thanks, Jason
  • Ovens Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
The f-1 error code is a fairly common problem with these ovens
This is either a controle panel issue or even the touch pad being faulty ok
Here is the test for it to determine which one it is
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Mar 13, 2011
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Am getting an "F-1" reading with a "beep"
Error code F1 means failed thermistor/transistor in control.
To resolve this issue you'll just have to replace the Electronic Range Control (ERC).
Good luck.
Apr 11, 2011 | Magic Chef 9815 Electric Single Oven
I have a magic chef gas range top , a drop in , and the igniters are all clicking at once , started on their own. any help. ??? Larry
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Dec 13, 2010 | Magic Chef Ovens
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
We have a Magic Chef glass top electric oven and the past few nights it has been beeping and showing a F-1 on stove top area
Hi
Thanks for using FixYa. F1 error indicates that the touchpad membrane is defective. To resolve this issue you’ll have to disconnect the ribbon strip: after disconnecting if there is no fault code then the membrane should be replaced, if the fault code still appears then the control board should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 08, 2010 | Magic Chef Ovens
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Ovens Logo
119 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
