Question about Optoma EP719 DLP Projector
Verticle flickering bar on left side of picture
  • 442 Answers
Use the "Frequency" menu setting to adjust the unit.
Check and reconfigure the display mode of your graphic card to
make it compatible with the product
Posted on Mar 14, 2011
Why does my Vizio TV show verticle colored bars on the right side of the picture and good clear picture on the left side?
The ribbon cables that carry the picture information from the screen driver to the LCD panel have come unstuck. However, because of the way these things are bonded to the screen in manufacture, you can't just fix it with a blob of glue. There are dozens of tiny filaments of wire all relying on a surface touch contact. If you remove the ribbon and then try to glue it back you'll never get all the contacts to touch.
The best thing to do is to leave the cable attached as it is, and then apply some pressure to the back to hold the contacts together. The perfect thing for this is some neoprene tubing. Is is soft and squashy enough to wedge in the space between the panel edge and the TV frame.
So, this isn't something that can be fixed by pressing a button. It needs a physical repair. If this sounds like it is beyound you then better safe than sorry, take the TV to a repair shiop. Good luck
Sep 17, 2014 | Televison & Video
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Picture up side down
change the verticle cables on the deflection coil on the tube.
note just the verticle cables ( verticle has only two cables)
what is happening is that current is reversed.
get it to some body a tech.
my tv gave me a similar problem.
Feb 08, 2009 | Bush 2871NTX 28" TV
Colored verticle bars, some w/colored snow,picture is still on
It sounds to me like you have a bad plasma panel. Unfortunately you may now be in the market for a new TV if you are not under a warranty of some kind. That issue is unfortunately unrepairable because it requires you to replace the entire panel and therefore is not cost effective.
Jan 23, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Philips TV Model 32DW6557/05 Screen Problem
hi it sounds like a capacitor in the verticle circuit located on the main board. it is near the verticle ic. the verticle ic also could be bad the cost is around 85 dollars for a tv shop to fix. sometime a cold joint could be found around vert ic. a soldering iron is required with solder.tap the side of tv if picture comes back it is just cold solder joint.
thanks Doctor video
Apr 25, 2008 | Televison & Video
LOSS OF T.V. PICTURE
My television has sound but no picture. I can not program the television because I can not see the screen menu. I also have tried to change the antennae but this does nothing to the picture's reception.
Do you have any ideas to correct this problem. There is no warranty.
Apr 11, 2006 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Optoma EP719 DLP Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
