Question about Garmin Colorado 300 Handheld GPS Receiver
Hello. I have a problem with my Garmin Colorado 300. When I connect it to pc by USB cabel the gps stays switched off. Normaly it must switch on, prepare the date for the transporte and after it is visible as new disk, but it stays switched off. So I switch it on manualy by it's power button (still joined by the USB cabel). PC recognize that there is a new device, but does not recognize it. Where is the problem? Thank you Karel Kralovec
SOURCE: Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Posted on Dec 01, 2007
SOURCE: Garmin GPSMap 60 CSx USB Connection
Actually, I just solved the problem myself...
I went to Garmin's driver download site (http://www8.garmin.com/support/download_details.jsp?id=591) and got the latest USB driver (2.2.1) for the 60C. (Although, it appears that that driver pertains to all Garmin products, not just the GPSmap series or the 60C.) Installation instructions are pretty much standard for Windows drivers, so it's easy.
That: a) Garmin requires special USB drivers for their product is finicky (most USB-connectable products just connect automatically using Windows' generic USB driver), and b) my unit -- which had always worked just fine, and suddenly stopped connecting out of the blue -- remains a mystery. Nonetheless, a driver upgrade was the final step that I needed. (Although, I also swapped USB cables and upgraded MapSource, too, so maybe it's some combination of those things.)
Posted on Sep 30, 2008
SOURCE: Garmin gps
trying to get street updates and an extra memory card / can not do it on the computor?
Posted on Nov 17, 2008
SOURCE: Garmin 205 w - I cant connect usb driver .I need the driver
you have to download a third party software to upload the maps, I used GPSsendmap, can be obtained free from cGPSmapper.com.
Just download sendMap20 rev. 6.0 for windows. It works.
Posted on Jan 20, 2009
  • 5 Answers
SOURCE: Problem connecting Garmin nuvi 205 w to pc
Check your cable.
I had to switch to device to pc cable from the garmin original cable to a pc cable that works with my motorola razor. The funny thing is I originally tried the motorola cable and it wouldn't work, brought the garmin cable and now it doesn't work but the motorola cable does.
Now my pc finds the device and I can go on to the garmin site and update.
Posted on Nov 11, 2009
Garmin Colorado 300 not turn on
Put a fresh set of batteries in it.
Connect it to a computer and run the Garmin WebUpdater program to load or reload the latest software.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 22, 2012 | Garmin Colorado 300 Handheld GPS Receiver
How do i reset my garmin colorado 300
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:\Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
> cd c:\Garmin
At the next command prompt type the following command without hitting enter:
> Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
May 07, 2011 | Garmin Colorado 300 Handheld GPS Receiver
Garmin gps powers off even when fully charged
If you're "recharging" via the car charger - you might want to try charging via USB jack on your computer - or AC adapter (if your GPS shipped with one) for 5 or more hours.
Many Garmin units develop this condition when used strictly in the car / cigar outlet power source. While connected to your computer, you should go to Garmin's website and download, install & run the "webupdater" software. When complete, your Garmin GPS will have the latest firmware and patches to the software (not maps!).
After charging via USB or AC adapter, your GPS should stay on. If your GPS turns on via a slide switch on the top, Slide the switch from OFF and hold in the ON position for 10 seconds before letting go of the switch. This should force a "boot" on the GPS.
If you're unable to get the device to power up, contact Garmin Support to determine if your device is affected by a a recent battery recall or if there are other suggestions they have to solve the problem.
I hope this helps!
Oct 08, 2010 | Garmin nuvi 650 GPS Receiver
I turn my Colorado 300 on, it starts, but dies while loading maps. Like the batteries were out, but they are new.
Hi, It seems to be backup battery on PCB. You have to replace it. It is very frequent defect for CO which was made, same battery there were used by Garmin was defect - shorter life time. Jean
Sep 11, 2010 | Garmin Colorado 300 Handheld GPS Receiver
My garmin colorado starts up with the logo of Garmin than nothing Not with a hrd reset neither with a soft reset I can only switch off when the batteries are taken out so start with wheel button pushed...
Hi, if USB connection is OK, you have to make hard reset after that download firmware 3.40 by Uploader (no Garmin WebUploader). Your Co will startup but your data will be lost. Jean
Jul 04, 2010 | Garmin Colorado 300 Handheld GPS Receiver
I have deleted pre loaded maps in my gps colorado 300. How do I reset.
If the maps are deleted they are gone! Contact Garmin and ask them to replace the maps. There is no way of resetting deleted maps.
Jun 14, 2009 | Garmin Colorado 300 Handheld GPS Receiver
My Garmin Colorado 300 is freezen
Better to update the colorado firmware to fix the certain problem on your unit.
Updates & Downloads Colorado 300 software version 2.90
Download (3.46 MB)
Installation Instructions
  1. Download the self-extracting archive file for your Colorado onto your hard drive.
  2. Connect your Colorado to a free USB port on your PC with the correct PC interface cable.
  3. Allow your Colorado to initialize and enter USB mode.
  4. Unzip the files in the archive by running the downloaded executable file.
  5. Follow the instructions provided by the launched update application on your computer.
Hope this initial info/idea helps.
Thank you for using fixya
Jun 07, 2009 | Garmin Colorado 300 Handheld GPS Receiver
Garmin Colorado 300 Handheld GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
