Question about Canon Video Cameras
XL1 Question: When I place a tape in and push the tray as in starts to lower, noise comes from within the head area like something is spinning on metal. HELP
  • 93 Answers
It may be a simple problem but don't try anything yourself since it could make things worse. Take it to a service centre.
Posted on Mar 13, 2011
My aiwa cd3 wont play cd,s. it takes the cd tray in but tray doesnt always place a cd directly under the playing head, and when it does the head onky spins a few times, stops ,spins 2 more times then
Get a can of the keyboard air cleaner? use the extension to blow up in the disk area ( usually a lot of dust pet hair etc in there)
It is possible that something is interfering with a sensor or the mechanical movement of the tray,. May be time to shop for a new one though ,, Best of luck
Aug 22, 2014 | Audio Players & Recorders
Owners manual
Place a flatblade screwdriver in the lower lip of the drawer, and manually force the tray out. It is okay to pull, you won't break the tray. It rides on a straight rail gear. After pulling on it, it should eject normally, but stay open. If it closes right away, there must be some blockage within the case. Using a flashlight, check to make sure no foreign object is blocking the tray. If the tray stays open, that is a good sign. Push it in and see if it closes on its own. Try pushing the button to eject. If the tray does not come out, take it in for service. If it comes out, perhaps the problem is solved.
Jan 26, 2014 | Sharp CD-C401 Shelf System
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Canon xl1 heads
Trained technician can clean the video heads individually and manually but I do not recomend it for general public. Best you can do is to purchase a good head cleaning tape. First, dust off the tape loading area with can air, then run the head cleaning tape for 10 seconds (our general recomendation is 5 seconds) but NO MORE. hope this works. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 11, 2009 | Canon XL1S Mini DV Digital Camcorder
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Mar 04, 2009 | Canon XL1S Mini DV Digital Camcorder
Tape player not working
i have had this problem with mine what you can try is when it does the clicking sound you can take your fingers reach under the black part w/ the head and gently push up when it clicks if you hear more clicks and the part moves then try pushing and holding the tape switch located at the left or right top corners of the player then press play if the head goes up but the clicks 3 times fallowed by 6 clicks the repeat the process. what is going on is if they r not use it tends to lock up
May 04, 2008 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Strange noise
Unusual noises that start after a mechanical device is dropped are never good regardless of the device. I would suspect that something is physically bent or out of alignment and continuing to use the camera risks additional damage. As to if you should still use it that depends on how much its worth to you and if you plan on repairing it later.
Feb 24, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Video Cameras Logo
24 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
