I have an extra hard drive that I would like to add as a slave HD to my computer the one I want to be a slave is a MAXTOR model 32049H2. how do I set up the jumper?
  • 79 Answers
I have an extra hard - moz-screenshot.pngI would guess that it is a diamond max driver, and therefore the jumper setting for slave should be no jumper at all. But in case I am mistaken, here are all the jumper setups for Maxtor drives, choose the one that looks like your setup and then choose the correct Slave setting:oss279.jpg
Posted on Mar 13, 2011
I have a maxtor 250 gb from a old hp computer model 6L250S0 do I need to setup as a slave hd
you only need to do this if you have only one IDE cable. If your are using SATA cables there is no need. IDE is the big wide ribbon cable SATA is the little blue connector.
Jan 12, 2015 | Maxtor Computers & Internet
Maxtor 32049h2 20.4 GB setup disk for windows 2000
After installing the hard drive in the computer then boot up with the Windows 2000 installation CD. Proceed with installing Windows. delete the existing partition , create a new partition, then format the hard disk in NTFS file format, follow the instruction to complete the installation.
You will also need the product installation code to complete the installation and you will need to activate the Windows license by the Internet or by phone. You will also need to install the motherboard device drivers.
Mar 14, 2013 | Maxtor DiamondMax VL 40 (32049H2) 20.4 GB...
I want to install the Maxtor 32049H2 N256 as slave Hd in my new computer how do I set the jumpers ?
hi frnds... step by step way are following link
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/
or
http://www.easeus.com/resource/install-ide-hard-drive.htm
Apr 25, 2009 | Maxtor Hard Drive
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor Model 32049H2 Slave jumper settings
Sep 04, 2008 | Computers & Internet
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
