Question about Car Audio & Video
I installed new dp video dp311x in my honda accord properly, but it wont turn on. i checked to see if there was power going into it with a test light, and ther is but it doesnt work. any advice as to what i should do?
  • 60 Answers
Did you check the fuse?
Posted on Mar 13, 2011
2003 honda accord lx cranks but wont start new battery starter fuel pump son drove it about a mile then drove home next day cranks but wont start
You must perform an engine control module fault code test as well as test the fuel pressure, if no codes are present and fuel pressure is ok check for a defective camshaft drive belt.
Apr 04, 2017 | 2003 Honda Accord
My 2000 honda accord ex wont start,
Is it a single loud click when you try to start it? Or multiple clicks or "buzz"? If it is a single click heard from the engine, your starter has likely failed. Test the battery first, and inspect the battery cables/connections for any looseness/corrosion.
Mar 13, 2014 | 2000 Honda Accord
1993 Honda accord, the battery is good but when i try to start it it wont turn over. The alternator is good and all my fuses are good, why wont it turn over? Should i get a new starter?
To begin with, turning over means different things to different people.
Does the engine crank but not start, or not crank at all ?
If it cranks but does not start, Honda cars are known to have weak fuel pump relays which would need to be tested.
Sep 29, 2012 | 1993 Honda Accord
I have a 1993 honda accord, just bought new battery,when i let it sit over night car wont start have to jump it off, something is killing my power
I just did this repair 2 weeks ago. Hope it is the same for you. It turned out to be the ignition switch. Not the actual tumbler that you insert your key in, but the switch mounted to it from behind. The part is $40. at Autozone. Remove the lower plastic steering column cover. Remove the plastic knee panel. You will see it screwed onto the the key column. It's most always white. It may function properly but inside this little switch are many contact points that when they fail, cause power to draw from your battery. For instance, you'll be able to turn your radio on and run your windows down even after you remove the key.
Apr 20, 2011 | 1990 Honda Accord
How to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
Mar 27, 2009 | Pioneer DEH-P2900MP CD Receiver...
98 honda accord wont start took starter to shop which passed the test. Need to know what other problem it could be...key turns all the way lights, radio all that comes on but wont start?
check your starter relay. if the starter passed the test at the shop check to see if you are getting signal to your solenoid on the starter it shoul be the little post when you turn the key to the crank position, check to see if you have power at the big post which comes from your battery, check your grounds. check your fuses see if you have a crank fuse or an ignition fuse.
Mar 06, 2009 | 1998 Honda Accord
98 Honda Accord Wont Start
either have a shop scan it for trouble codes or buy a scanner your self at local parts store have OBDII scanner and find out for your self it could be a number of things.
Feb 24, 2009 | 1998 Honda Accord
91 Honda Accord No spark
If the timing belt is damaged(broken or missing teeth) you will get no spark. One easy way to tell is that many times the engine will sound different as it turns over, than it used to.
Oct 05, 2008 | 1991 Honda Accord
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
