Question about Element Electronics FLX3711B 37 in. LCD TV
I was just given an Element Electronics FLX-3711B 37" wide screen tv but there is no power supply. Is it a specific power supply or will a computers power cord work since they have the same style ends? If specific what are the specs I need to get? Thank you
    Master:
  • 403 Answers
You will need the power specs of each unit, look on the tv and computer near where they plug in, should be tagged right there or somewhere close. by law it has to be tagged. if not right there keep looking . and yes it is specific.
Posted on Mar 13, 2011
My tv goes loud and low
is it the TV or the source? Does it do this on all inputs? try attaching DVD player.
Be sure all your connecting cables are good & installed all the way on both ends. if still have issue, may be your Main PCB
part#
ELEMENT FLX-3711B MAIN BOARD 899-KE0-UF3712XA1H & Signal Board 899-100-GF271XAH
try this web site for element parts: http://www.ebay.ca/sch/sis.html?_nkw=Polaroid%20899%20KE0%20KF371XA%203H%20Main%20Board%20VSC%2037V1&_itemId=161027387391
May 08, 2014 | Element Electronics FLX3711B 37 in. LCD TV
Element tv dark no picture
This is a very common issue with that model. There are filter capacitors on the power supply board that fail and keep the back light power section from starting up correctly so you get no picture on the screen. The FLX-1910 uses the same power supply board of the Polaroid TLA-01911, below is a link to information showing how to repair this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
Nov 08, 2012 | Element Electronics FLX-1910 19 in. LCD...
My lcd element FLX-3711B dont turn on.. I plug the cord cable and only flashing front red light? Whats the problem?
The Element FLX-3711b TV is the same unit as several model of Polaroid and Visco TVs. They are all made by the same company just labeled fr different brands. The flashing power light is a very common problem and is caused by a failure of the power supply board. The capacitors on the board short out and this causes the board to not power up correctly. Here is a link to a repair guide for the Visco TV that is the same as the Element FLX-3711B so the information will be the same for both units. The repair guide shows the parts that will need to be replaced on the power supply board to rebuild it.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps you out.
BuddyMc
Jul 10, 2012 | Televison & Video
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
BuddyMc
Jan 30, 2011 | Element Electronics FLX-2210 22 in. LCD...
Bought element tv model flx-3711b in 2008, worked well until about a month ago start having problems, it start taking longer time to come on, sometimes picture comes on but no sound and sometime loud sound...
The problem you are having is a common and easily repaired one. The problem is caused by a failing power supply board. If you can do a little soldering then you should be able to do the repair. Check out this article on repairing the power supply in this model.
If you don't want to do the repair yourself we do offer a repair service, you can use the link on that page to request service.
I hope this helps you, if so please rate our solution.
BuddyMc
Jan 11, 2011 | Element Electronics FLX3711B 37 in. LCD TV
I possibly had a surge on my Element FLX-3711B Tv. It was also connected to a sony surround sound station. The sont was off for a while but reset it self after awhile and now works fine. My TV has not...
Tv now have LED indication power light on the screen panel blinking light or totally dead,no light at all?The power supply board,that the board where the power a/c cord plug into it.That the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 16, 2010 | Element Electronics FLX3711B 37 in. LCD TV
Element FLX-3710 37" LCD tv will not turn on
power supply problem of course...set is not dead so line fuse would be good as you said...regulating power supplies are very stable but do contain >>>CAPs<<< caps can leak ,swell do to heat ,etc.
check for visible signs of damage to caps. on circuit board...check regulating transistor( on heat sink)
the >>> on off on off routine<<< makes me think check caps!!!!!
May 19, 2010 | Element Electronics FLX3711B 37 in. LCD TV
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Element Electronics FLX3711B 37 in. LCD TV Logo
115 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
