Question about Garden
How do you adjust the fuel mixture - Garden
    Master:
  • 403 Answers
What are you trying to adjust on. but you will have 2 adjusting screws, not to be confussed with idle screw
Posted on Mar 13, 2011
How do I adjust the CO and fuel/air mixture
the CO and fuel/air mixture is not adjustable on modern cars , only on carburettors . the engine management system will ensure correct fuelling, if there is a fault with this then in most cases an engine management light will illuminate on the dash board
Feb 17, 2015 | 2000 Daewoo Nubira
Yamaha 250 xt looses power in second gear it is as if there is no fuel getting through from the carb
The mixture adjustment should be for idle or idle fuel mixture. Even if that mixture adjustment is off, that will not stop it from making power in second gear. If the motorcycle has been sitting for more than 6 month without being run, the carburetor and fuel system probably needs cleaning.
Feb 01, 2015 | Yamaha Motorcycles
2005 Honda Activa air-fuel mixture adjustment
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Adjusting air fuel mixture screw
Honda Activa Fuel Mixture screw Actual Adjustment and RPM Adjustment
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Feb 14, 2014 | 2005 Honda Activa
Adjust air fuel mixture
Hi Wentzpatrick, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. There is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/4 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time. Good luck.
Jul 15, 2013 | Harley Davidson XLH Sportster 883...
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
YZ450 setting idle pilot screw popping on decel YZ 400 426 450
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
YAMAHA YZ450F Owner Service Manual
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jun 02, 2013 | Yamaha YZ 450 F Motorcycles
How do I adjust the fuel mixture on the ford 460 efi
The mixture is not adjustable.
You have fuel injectors that are controlled by the computer.
If the check engine light is not on, I would look for a fuel pressure problem or a leaking injector.
Feb 06, 2013 | Cars & Trucks
Fuel mixture adjustment of honda activa
https://itstillruns.com/adjust-honda-carburetor-5347552.html
Dec 01, 2012 | 2005 Honda Activa
How to adjust idle on fj 1200
FUEL MIXTURE SCREW ADJUSTMENT PROCEDURE
Carb tunning
Yamaha 1992 FJ1200 Service Manual
http://mybikemanuals.com/yamaha/yamaha-fj-owners-manuals
Nov 16, 2012 | Yamaha Motorcycles
1999 Road King Carb Adjustment
Hi Anonymous, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. There is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/4 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time, final adjustment should be made with the engine at normal operating temperature. Good luck and hace nice day.
Apr 27, 2012 | Harley Davidson FLHR-FLHRI Road king...
I have a 1987 gmc jimmy with a 5.7 litre fuel injection and it seems to be lack air or has to much i dnt know . and i want to know how to adjust my fuel air mixture
Unfortunately, most fuel injection engines don't have an adjustable fuel/air mixture by the technician.
The fuel/air mixture is controlled by a computer.
Jul 03, 2010 | 1987 GMC Jimmy
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
