Question about Stanley Tools & Hardware - Others
I have a old Stanley door planer and cannot find cutter for it. Model 550.01
    Novelist:
  • 157 Answers
Hello. Your best bet is to go through Stanley themselves. About half way down is the "Parts and Service" link to identify the part number of the cutter itself. There is also a "retailer locator" assistant to use once you have the information, that way you can possibly avoid any shipping charges. Hope this helps, if so please rate a four-thumbs up. Thank You.
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
Posted on Apr 06, 2011
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
I found a combunation plane no 50 in my shed how do i use it
If this is a cast iron, nickle plated Stanley number 50 it is considered by many to be a collectors item and is between 50-140 yrs old. Depending on condition, original box, manual etc, this plane could be worth $150 or more to a collector.
As for using the plane, here is a link to the site "Cornish Woodworking" which does a great job explaining the parts and use of ploughs and planers.
http://www.cornishworkshop.co.uk/combihow.html
Dec 19, 2010 | Stanley Hand Tools
Stanley carpet cutter model 10-525 fell apart. I need to know correct assembly.
This is a terrible tool took it apart to get the blade out of the handle and haven't been able to get it back together again.
Oct 22, 2010 | Stanley Garden
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
How to Fix Doors and Windows?
Take a look around the house or any place where you're using doors that don't swing clearly open and closed. Check to see that the door doesn't have a problem with its hinges but is actually a millimeter (or a few) too large on the top or bottom, since this is a perfect use for held power planers. Look for ragged or rough edges on wooden planks built into things like handmade bookcases. Also find imbalances on the bottom of wooden chairs and tables that cause an annoying rocking that is easily corrected by the held power planer. Use the planer to make rabbets (sometimes called rebates), or smooth and even grooves in a piece of wood that can accommodate the edge of a piece of glass, sealant or putty. Thin out pieces of wood used for do-it-yourself jobs if the wood expands from humidity and moisture. Let the wood settle in the place that it will permanently sit and then user the planer to plane the wood to the correct size. Do the work in the place that the wood will occupy if it's feasible. Take a look at wooden window frames that cause the window to stick or open and close roughly. Plane the window frame a millimeter at a time to get the window to run correctly.
Aug 27, 2008 | Bailey Stanley 12-960 - Low Angle Block...
Planer or Jointer
If I had to pick, I would get the planer first. That way you can at least get your lumber pretty darn close to flat and parallel. Furthermore you can resize your lumber when necessary. But that’s just my opinion.
Aug 27, 2008 | Rockler 24? Precision Straight Edge
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Aug 27, 2008 | Bailey Stanley 12-920 - Block Plane
Tools & Hardware - Others Logo
143 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
