Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
My yard machine sat in the garage for the winter. I dumped the old gas and replace with new. I checked the plug and tried to start. it started a few seconds and died. the primer pump diesnt feel like it does anything. I attempted to start the machine and it seems like it is about to start but doesnt. what should i do
trippssmengi
  • 76 Answers
SOURCE: Tiller won't start
You may need to perform a rebuild or possibly a good cleaning on the carb. any questions on it feel free to ask
Posted on Mar 17, 2009
  • 376 Answers
SOURCE: 158cc yard machine, starts then dies.
Your fuel tank and carb need to be removed, both cleaned and replace pump diaphragm between carb and tank. If you want to do it yourself, let me know and I;ll tell you how. Not a difficult job. Dwain
Posted on May 26, 2009
  • 16 Answers
SOURCE: bought yard machine lawnmower new lest than a year
sounds like you may need a new solenoid switch or starter switch I would check them frist hope that helps
Posted on Aug 28, 2009
Testimonial: "very good advice and clear to the point"
  • 53 Answers
SOURCE: Yard Machines rototiller front tine- having problems starting
Sounds like you are either losing your "prime" or your carb needs either, cleaning, rebuilding with a kit. Probably a cleaning will do it. Watch U Tube there are wonderful people who film the whole process from tear down, to replacement. Com'on! Get into it its easy and it don't take long. Then you'll always know how to do it!
Posted on May 06, 2010
SOURCE: Yard machine carb issues
clean the main jet and check the pickup tube if this carb is a tank mounted side draft carb.
Posted on Jul 19, 2010
Engine won't start- I have changed gas, I have a good spark, and no air blockages
Put a nice new spark plug in the engine and clean the carb with carb cleaner. Spray some cleaner in the carb throat, and put some liquid carb cleaner in the fuel tank.
Mar 05, 2014 | Troy-Bilt Super Tomahawk Chipper Shredder...
I have a 1996 mustang with a 2005 f-150 engine in it. It has sat in a garage for 7 months without being started,what should i do before starting it?
hi,im elroy, u should change the oil and oil filter,drain old oil and refill with new oil, dont forget to change the oil filter before you refill with new oil.change all spark plugs
Feb 01, 2013 | 2005 Ford F-150
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Honda hrb423 mower wont start have checked spark plug works any other suggestions pliz
Check the air filter and ensure that the fuel is pretty new. Today's fuel goes starts to go bad after about a month. So if the gas you left gas in it from last season or put old gas in it, it may well not start. Dump out the old stuff and put in new. If it sat with old gas and changing the gas will not let it start them you may have to clean the carb.
Jul 14, 2011 | Garden
I have a p-3416 poulan saw it is getting spark but the saw still wont start
It's not getting gas. Possible wrong mix oil to gas, but not real likely. Possible sat over the last winter with gas in it and varnished. I'm guessing this is the one, more likely than not. take cover and filter off and clean and bag 'em. pour carb cleaner in the carb and soak overnight. Dump out (carb cleaner and old gas)into a sealable jar or can and fill with straight gas and soak an hour and dump into trash gas/carb cleaner. Use a bicycle pump to blow air into carb to dry it. At most use a computer air can. Then start with the right gas/oil mix, prime it, set the trigger and choke and drop start. (It helps to have the spark plug out during the soak. Then clean it and sandpaper the gap and the magneto area on the flywheel).
Jun 18, 2010 | Garden
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Yard machine mtd 123cc mower stalls after starting it runs for a few seconds and then stalls. Previous to this it only ran on choke but when you took the chock off it stalled also. Now it stalls even when...
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Aug 16, 2009 | Mtd 22" Yard Machine Push Mower
I can't get it to start, it just sputters for about 10 seconds and cuts out.
If your tiller sat all winter it will need a little work. Drain all of the old fuel out of the tank, install a new spark plug and install a new air filter. Put new fuel in the tank [if you still have old fuel in your portable gas tank dump it into your car or truck so you start fresh for all of your small gas engines.
Now crank it over and it may start. If it doesn't start you need carbeurator cleaner. But an aerosol can of carb cleaner and put two squirts in the air intake [remove the new air filter and leave it off while you get the engine running]. Pull your cord, turninng the engine over and possibly starting it. If it starts, great. If not, let it sit for half hour while that carb. cleaner dissolves some of the gum built up in your carberator over the winter. Two more squirts of carb cleaner and try to start it again.
Generally it will start by now. If it doesn't start your carbeurator must be really dirty. You will have to remove it, and soak it in carb. cleaner for about three hours to clean it out.
May 27, 2009 | Mantis 2-Cycle Tiller
My car sat in a garage all winter and now it wont start. i have replaced the battery and it has spark. i dumped in a bottle of heet but still no luck. can anyone give me a hint? Thanks!
take the gas cap off for a few minutes and gently tap on the bottom of the gas tank to make sure that the float is not stuck because if the float is stuck it would be telling the car that it is out of gas and the reason for taking off the gas cap is for vacuum pressure
Apr 19, 2009 | 2004 Mazda RX-8
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
29 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
