Question about HP Office Equipment & Supplies
I need a driver for a video card I installed in an older computer running Windows ME. The video card is the input for the my surveillance system. Do I need a specific driver or will a generic PCI Video driver work and where can I download this?
  • 86 Answers
Just google the type of video card you are using followed by the word "driver". You should be able to find it and download the software.
Posted on Mar 12, 2011
EasyCap input audio quality problem!! HELP
You have told us the operating system, but not what type of computer you have. For example if the video from the device is good you could, if the computer has an audio in socket, use that to connect the device. Many VCR's etc have audio out so just use that as a direct connection, then it doesn't matter if the capture device sound settings don't match your computer's. The main thing is the video feed is good.
Mar 15, 2014 | Universal EasyCAP USB 2.0 Audio/Video...
Is there software avaliable to hook up mini dvr to computer
You need to install an interface card in your computer, and it does come with the software.
You need a card that has the video Input (AUX).
The Hauppauge Win TV HVR-1600 is a Plug-in card with TV and Video Input.
www.aaatvservice.com
Jan 26, 2012 | Mini Dvr Digital Video Recorder For Aqua...
I have Some Problem about my Video Controller VGA compatible.. It so hard 2 find a compatible VGA 4 my System hope u can Help me. here`s some information of my System.... Operating System: Windows...
To find video drivers for unknown cards, you have a couple options. If you are comfortable opening the chassis of the computer, you can look on the video card itself for its model number, and then google for that model number. I've always been able to locate drivers in this way. If you are not comfortable going the hardware route, there is an application called System Info for Windows (SIW.) It can be downloaded HERE. Once you install and run the application, you can click on the "Video" node and the model name will be shown on the right (usually in the PCI ID section.) You can then google for the model name and find the driver that way
Feb 28, 2011 | Computers & Internet
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
I recently installed the latest drivers for an nvidia gforce 8500 gt card, and now every single game i try to play crashes. after a few minutes into the game (any game), the monitor goes black, and then...
Not an unusual situation. Try older drivers for the card. You have a couple of options.
1) If you're running a later Windows version, you can revert to earlier drivers with a System Restore. There should be a Help and Support option under your start menu, use that to revert to a time prior to when you updated your drivers.
2) If the last set of drivers you've installed worked, under Windows Explorer, you should have a C:\NVIDIA\DisplayDriver\ folder. Look for a setup.exe file under the fileset before the latest set of drivers, and run that. It should revert you to the driver version that last worked for you.
3) If all else fails, browse to www.nvidia.com, select your region, and from the Download Drivers dropdown, select 'Beta and Archived Drivers'. Select the appropriate settings for your OS and video card, and click 'Search'. You'll find older drivers for your system there. Keep installing older driver versions and test games until you find a driver that works for you.
Nov 29, 2010 | Nvidia GeForce 9500 GT, PCI Express Video...
I get a "input signal out of range" with windows nt. Is it my frequency or resolution settings and can I correct it?
well it is maybe the video cards fault. But you could try installing windows xp or newer or older video drivers
Sep 28, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
When playing videos on my computer the video driver fails and the video screen goes green... I get a message saying "video driver failed but has recovered" Happens every time i try to watch a video. I'm...
Most probably the drivers downloaded from Nvidia is not the correct version or an older version for your video card. That is probably windows revert the best options drivers for your video card. You can check the version or the date windows automatically installed from the device manager. You also can also use "Microsoft Updates" to update your drivers.
To remove the video drivers, go to "safemode" and from the "device manager" uninstalled the video drivers.Be sure to download the correct version for you video card and run the installer from Nvidia.
Do update your DirectX too.
Hope it helps.
Jul 29, 2010 | Computers & Internet
Download pci cx11252 11 modem driver for windows 7
This does not work for windows 7, tried and win7 rejects the device, also on properties it only goes up to Windows Vista.
Apr 05, 2010 | Conexant CX11252-11 Modem
Will not work with Windows 7, is there a driver that will work.
I was having the same problem, and the answer is a little tricky, but should work fine. You need another computer running xp or vista. Go to the other computer, then install the software from the included disk. Download Drivermax (http://www.innovative-sol.com/drivermax/index.htm) and install it on the xp/vista computer. Then, plug the receiver unit into the xp/vista computer, and wait for the hardware to be installed. Once the receiver is installed (you can test this by running "Uniden Surveillance System" and turning on a camera), leave the receiver plugged in and run drivermax. Click on "Backup Drivers" under "Driver Backup and Restore". Click next, and wait for it to list all of your devices (this could take a while, depending on your devices). When they have all listed, scroll through the list until you see "Wireless Digital Camera" or similar. Check the checkbox next to that, and click next. Save the file on a usb drive and disconnect the receiver and the usb drive with the driver on it. Go to the Windows 7 computer, and make sure the Uniden Surveillance System software is installed. Plug in the receiver and wait for windows to try to install the software. When it shows the error, go to printers and devices, and double click the icon for the receiver, under the unrecognized category. Click troubleshoot, and it will try to figure out the problem. Once it asks you where to look for the driver (Windows Update or a file on your computer), click the option for the file on your computer, and browse to the folder on your usb drive. Continue, and it will search the folder for the files it needs. For me this took a while, but wait for it to finish installing the driver. Once it does, you're done! Start up the software and try out your camera!
This worked fine with me, using an XP driver on a windows 7 netbook.
Jan 07, 2010 | Uniden UDW10003 Wireless Portable Video...
Intel D815EEA - my VGA built-in isnt working
If the previous video drivers were not removed properly—and this generally requires running a “cleaner” utility in addition to uninstalling the drivers—the computer may be unstable with the new drivers installed. Also, some OSes (operating systems), such as Windows XP, automatically try to find and install graphics drivers following the obligatory reboot after a user uninstalls the old video drivers. Games may also close and drop the user back to the Desktop, and the system may spontaneously reboot.
Problems may also occur if the user installed drivers for the wrong graphics chipset, although manufacturers such as Nvidia and ATI provide all-in-one drivers to cover many graphics chipsets in one package.
Visit the Web site of the manufacturer of the graphics chip on your card or motherboard, such as Nvidia, ATI, Intel, or others. In the graphics driver download section, look for an uninstaller or cleaner utility. An example is ATI’s Catalyst Uninstaller, which is typically offered on the same pages as specific driver downloads. Download the uninstaller/cleaner utility and run it, following its instructions. Reboot and then install the latest graphics drivers for your specific card or motherboard.
A free, third-party alternative is Driver Cleaner. This has generally been safe to run as of this writing. Be sure to read all notes and follow all directions as you use Driver Cleaner to remove old driver remnants. Use the software to get rid of any drivers supplied by Windows, too, as these are often the ones WinXP automatically installs at startup before you can install the new drivers from the graphics chipset manufacturer. You probably won’t need Windows’ drivers again, as they’re usually older and slower and don’t have the latest tweaks and fixes.
Make sure you’ve properly identified your graphics chipset. First, check it in Device Manager (right-click My Computer and click Properties, the Hardware tab, Device Manager, and Display Adapters). Corroborate this by opening your computer’s case and checking the brand name and model number of your graphics card (the monitor’s cable connects to it) or the brand and model of your motherboard if the video/graphics chipset is built into it. Look up the model number on the manufacturer’s Web site, and it should tell you which graphics chipset you have.
Note that you can install ATI’s or Nvidia’s drivers on any card using their chipsets (no matter whose brand is on the card). On the other hand, if you have integrated graphics, you need to get drivers from the motherboard’s manufacturer.
If you have recently changed from integrated graphics to an add-in video card, make sure that you have moved the monitor cable to the new device and disabled the motherboard’s onboard graphics in the BIOS (Basic Input/Output System). To do so, click the indicated button to enter Setup during the boot process, usually the DELETE button. Then, look for an option that will let you disable the BIOS’ onboard or integrated video.
Feb 15, 2008 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
52 people viewed this question
Seeker5211
Seeker5211
