Question about Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump
25 lb oil free air compressor craftman not building pressure
    Problem Solver:
  • 3 Answers
LOOKS like regulator worn out or if compressor has heavy whispering sound means not generating enough pressure to go through the check valve.
Posted on Apr 24, 2017
    Master:
  • 403 Answers
Most likly the regulator is no good, some can be serviced, some are sealed units.
Posted on Mar 13, 2011
Air compressor starts and builds air then idles and when it goes to rebuild air it dies
if your saying it wont recover from idle down mode back to full speed , this might be the IR fuel pump/regulator problem (a pressure gauge will need to be added to verify this ) , if so save your money go with an aftermarket pump it'll last longer
Mar 25, 2014 | Ingersoll Rand Air Tools & Compressors
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
AIR PRESSURE WILL NOT GO OVER 40 LB . CHANGED THE PRESSURE SWITCH CHECK VALVE PUT NEW COMPRESSION RING KIT ALSO TOOK OFF THE PRESSURE REG. OFF FOR A WHILE. AND STILL WILL NOT GO OVER 40 LB
Hi, my name is John. Welcome to FixYa. Check the line coming from the pump to the tank for a split or hole, I have found that this is some how over looked. You may have to remove the line to inspect it. Check all hoses for air leaks. Thanks for choosing FixYa...John
Nov 20, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Jan 07, 2009 | 2004 Chevrolet Aveo
Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump Logo
396 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
