Question about Casio FX-115ES Scientific Calculator
Can i plot graphs using fx 115 es? - Casio FX-115ES Scientific Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
The fx-115ES is not a graphics calculator so it will not display graphs on its screen. You can use it to make graphs by calculating the points and plotting them on graph paper.
Posted on Mar 12, 2011
How to do plot and whiskers in a casio fx-115ES calculator
This is not a graphing calculator, so you cannot perform a box and whiskers plot.
If you know how to find the Median(=Q2), the lower (Q1), and upper (Q3) quartiles, you can draw your box and whiskers plot on a piece of paper.
Jul 21, 2014 | Casio FX-115ES Scientific Calculator
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
Which model of casio csn do integration in limits
The Casios FX-115 ES , FX-115 ES PLus, FX-991 ES, FX-991 ES Plus C can perfom numerical differentiation at a point, and numerical integration between two given limits.
Aug 12, 2013 | Casio FX991ES Scientific Calculator
My fx-115 es wont allow any decimals, and the word 'dec' appears on the screen at all times
Try reseting it by pressing "shift" , "9" , and "3" in that order after you turn it on. It might fix it mine did the same thing and it fixed it.
Apr 23, 2012 | Casio FX-115 Solar 236 Function Scientific...
How do you find the equation of a exponential graph
Usually ypu know the equation then graph it. However in doing statistics, it may appear that the curve of best for a scatter plot could be could an exponential. In that case you use the STAT application to enter the x-data in List 1 and the y-data in List 2. When you finish press the f1 key to select Graph1. You should also verify by Pressing F6:set that the graph type is set to scatter, and that List 1 contains the x-data and List 2, the y-data. After you verify that all is in order press the F1: Graph 1 key.
As the graph is displayed you will see several tabs with various regression models. Pan thr tabs to the right to get to F2:EXP. Select it.
The equation is displayed on the next screen. At the bottom of the screen you see two tabs COPY and DRAW. Press f5:Copy to copy the equation in one of the y= functions.
Press Draw and you will see the curve of best fit superposed on the scatter plot points.
Aug 23, 2011 | Casio FX-9750GPlus Calculator
I cant get my graphs to plot right on my graph mode!! when I plot the sinX curve, I get a linear line that looks a lot like y=x and when I plot my cosX curve, I get y=1 HELPPP!
I believe it has to do with your angle unit. If you angle unit is set to degree and your default window dimensions are -10, 10, then the sine function will look like y=x ( straight line) and y=cos(X) is approximately 1 in that domain.
Your solution is one of the following.
Use degree as angle unit, but change the window dimensions for x to -180 to 180 and the y-dimensions to the interval -1 to 1.
Use the radian angle unit and leave the Xmin-Xmax interval -10 to 10.
May 04, 2011 | Casio FX-9860G Slim Graphic Calculator
How do I factor using the fx-115 ES calculator? would a problem like 9x^2+24x+16-Z^2 be solvable on this calculator? If not, does Casio sell any calculators that would help me factor this equation?
No, your calculator cannot factor polynomials. You need a calculator that has a CAS (computer Algebra System)
Yes Casio sells calculators with CAS: The FX-Algebra 2.0 and 1.0, the FX-9860GPLUS/GII SD, the GRAPH85 or 80 and the Graph 100+. You also have the CLASSPAD Series 300PLUS and 330.
TI and HP also have CAS calculators.
Texas Instruments
TI 89 /Titanium, Voyage 200PLT, TI92PLUS (discontinued), TI Inspire CAS.
Hewlet-Packard
HP 48G/G+/GX, HP40G, HP49G/G+ and the top of the line HP50G
Oct 28, 2010 | Casio FX-115ES Scientific Calculator
Steps to draw graphs using Fx 991 ES Plus calculator.
There are many different functions...
You can download the entire manual after answering a few questions at www.safemanuals.com
after using the dropdown menu for this make and model.
Good Luck!
Oct 18, 2010 | Casio FX-115ES Scientific Calculator
Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Math book for the fx-115-es
Use your internet seach engine or go to the casio worldwide web site. A google search returned this link to the New-Zealand site.
http://casionz.co.nz/Site/Pronto/Files/user_manuals/FX-115ES%20991ES.PDF
Hope it helps
Mar 09, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
387 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
