Question about Whirlpool Calypso GVW9959K Top Load Washer
"CE" comes up when we turn washer on. We've
  • 4,323 Answers
Hi
CE is a communication error which flashes if there is any breakdown in communication between the machine controller and the motor controller. To solve this issue check the drive motor and the motor controller and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 12, 2011
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
LG Washing Machine with CE error code with laundry in the machine and cannot open the door
Problem:
Getting a CE error code
Solution:
This is a *rare* error.
It's highly unlikely the motor is at fault.
Detergent overuse triggers an "LE" error rather than "CE".
UNPLUG THE WASHER...
First--inspect all wiring connections at the MAIN BOARD . If good...
Inspect the wiring at the motor--remove the rear service access panel.
Remove the 17mm bolt at the center of the rotor--this can be tight as threadlocker is used (I use an 18 volt Dewalt Impact drill).
Pull off the round shaped rotor. Use some care--this rotor has magnets lining the inside of it--it's not super fragile but can crack if hit sharply.
Inspect the two plug connections to the motor for loose or frayed wiring. Also inspect the wiring which runs from the base (bottom) of the washer-to-the-motor. Once or twice--I have found wiring frayed from the gyrating tub assembly (repair as needed).
If no obstruction such as a nail or similar object can be seen in the drum (small holes in tub)...if the drum turns freely by hand--the most likely fault will be the MAIN BOARD has failed.
This job is very simple.
Wm2277 service manual
Sep 14, 2012 | LG WM-2277HW Front Load Washer
Hello: I have an LG front load Washer Model #WM2010C. Its' receiving a error code (de). I've looked it up and it seems to be "door error." I cannot open the door. When I go to...
You will need a new door llock switch.
to change it you will need to loosen the front bellow by removing clamp, unscrew the twwo scrwes holding the switch then unplug wires to switch and re-install.
Jul 02, 2011 | Washing Machines
Ever time we switch on ce comes up
The CE error code tells you there is an over current in the motor. Unplug the power cord, wait for 10 seconds, plug the washer back in, and restart the cycle. If same problem happens again, close the water tap, unplug the unit.
You then have to decide whether to call for service or try to fix it yourself. You will most likely have to change the motot stator (Part #1267510) that costs about $125.00 and Control Board (Part #1268301) that costs about $60.00. Plus fix whatever problem caused it like a water line allowing water to drip on the stator.
Sorry for the bad news.
Jun 05, 2011 | LG WM-2277HW Front Load Washer
Code ce dont turn on
The CE error code is indicative of an over current in the motor. Unplug the power cord, wait for 10 seconds, plug the washer back in, and restart the cycle. If same problem happens again, close the water tap, unplug the unit, and refer to service
Thank You
Sep 12, 2010 | LG WM-2277HW Front Load Washer
PWER WASHER RUNS PERFECT, WHEN WATER COMES ON, IT STALLS. BUT IF YOU PULL TRIGGER BACK ON WAND, THEN SPRAYER WORKS. THE MINUTE YOU LET GO OF TRIGGER, IT STALLS OUT.
hi you have got a fault with the unloader it's not unloading so its going a bove the 13amps and knocking the thermol overload out or blowing a fuse you could cable tie the trigger open or get a new unloader kit costing about £70.00 regards
Feb 17, 2010 | RTO 1800 PSI Pressure Washer
How can i fix the CE code on my washer? the CE code appears when i turn on the washer then it turns off.
The "ce" code indicates that a communication error occurred between the central control unit and the motor control unit. This can be caused by poor or loose electrical connections, especially at the motor connector. Unplug the machine before attempting any repair. The electrical connections can be unplugged and reseated to clean off corrosion. Also look for any damaged or burnt insulation on the wiring. If these steps fail to resolve the problem, you may want to consult an appliance repair technician for assistance. Sorry for your trouble and best wishes.
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Removing unloader valve
If you can't get it out with needle nose pilers try turning the garden hose pressure on and the water should pop it out.
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
