Question about FrancisFrancis! X6 TRIO
My Francis Francis pump does not start. When the green light come on I put the coffee pod and press the coffee making button and nothing happens. Any help resolving this problem is appreciated.
  • 3 Answers
SOURCE: Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Posted on Jul 14, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Posted on Mar 09, 2009
SOURCE: I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Posted on May 21, 2009
  • 1089 Answers
SOURCE: Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Posted on Jun 16, 2009
HizerKite
  • 9 Answers
SOURCE: I had bought Coffee machine francis!francis X2
Do the power and heater lights illuminate?
Posted on Aug 30, 2009
The red light comes on and then goes green. Filled with water and pod in but nothing happens. Completely silent.
one step at a time do you get water with out putting the capsule
what is it doing is there any sound coming from the pump do you have any flashing red light? need more info
Jan 11, 2016 | Krups Dolce Gusto KP 2100 Espresso Machine
When pod is put into machine green light doesn't always come on therefor no coffee & a wasted pod
I know, don't you hate when that happens? Did you check to see that the needle port where the hot water exits from is free of debris? If plugged, no water can escape, thus I suggest using a pin or small paper clip end and stick it up the tube to free it up. See if that helps.
Feb 03, 2015 | Bosch TASSIMO Coffee Makers & Espresso...
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
Fill tank with water and put plastic coffee pod in place. Press the power button and cup size and nothing happens except a smelly substance is injected into the water tank.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig B60 Coffee Maker
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X6 TRIO Logo
147 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
