Question about Westinghouse Washing Machines
Hello we have a westinghouse washing machine model LT8195 in which we are getting a Ld display and themachine will not start, can you please offer assistance thank you regards andrew
scottowa
  • 87 Answers
SOURCE: washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
Posted on Jan 22, 2009
SOURCE: error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Posted on Feb 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: We have a Kenmore Elite Calypso, it is not washing
Hi
Thanks for using FixYa. Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 15, 2009
  • 6277 Answers
SOURCE: need a manual for a
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 28, 2011
jyackle5
  • 8197 Answers
SOURCE: i have a westinghouse washing
The only way to get the manual for your washer is to contact Westinghouse at
1 (866) 942-0437
Monday - Friday
9:00 am - 5:30 pm EST
They are the only ones that have the manual of the machine.
Good Luck
I have a Westinghouse LT8195 washing machine,error code is coming up SP ? Do know what this is ? Please help
I think you may have used the wrong kind of detergent or too much.your washer is most likely over SUDs.If you don't use he High Efficiency detergent this will happen. There is a he swirl on the container.shut down you washer for a half hour let it settle. Clear the drain as best you can from suds. if your model has a no spin or low spin use your rinse cycle.you may have to do this again if suds are to thick. Westinghouse has an SD code for SUDs. If you have an owner manual check it.continue to wash normally
Jul 27, 2015 | Westinghouse Washing Machines
LD error
LD is long drain time. Be sure there is no blockage in the drain line and clear the filter if there is one. What is the model number of the unit?
Nov 28, 2012 | Westinghouse Washing Machines
I have a whirlpool washer. model G V W 9959KQ. It is giving me an LD error code.
The LD error code means LONG DRAIN time and usually the reason it displays that code is because something it caught in the drain pump,thusly since something is in the pump its taking a very long time to drain the water.
GENE
Sep 23, 2011 | Washing Machines
Heard a beeping warning half way through cycle. Went in and Ld was message flashing. Tried to stop and restart, then machine started making buzzing noise. Cannot get machine to do anythind but lock lid...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 16, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Won't finish a wash - LD is displayed. took everything out & tried to do a cycle so that the water will drain & it still says LD. Purchased in 2002 and this is the same problem that happens...
Kevin
Aug 07, 2011 | Washing Machines
Need a manual for a westinghouse lt8195 PLEASE!! have been trying to use it and i just dont understand what its doing, someone please help!!
John C.
May 28, 2011 | Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
'LD' on display and lid closing won't get the washer started
Hi just read your posting.Now I know you supplied the model number in your posting but could you please supply the name of the machine which should be written on the control panel.Is it an ENDURO or an ESPRIT --etc--?Please reply with additional information and I can help you rectify this problem.Looking forward to your reply.
Jul 27, 2010 | Fisher Paykel Eco IWL16
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
