Question about Bosch Nexxt 500 Dryer
Dryer stopped in the middle of a cycle. Time kept going, drum and motor stopped. Unplugged dryer, check lint and exhaust hose for build up. Plugged dryer back in, when I select time and hit start, dryer clicks like it wants to start but dryer dose not run.
    President:
  • 3,074 Answers
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Posted on Mar 13, 2011
Takes about 4 hours to dry any load. Have tried different settings. Husband cleaned lint traps, hoses, etc. Gas turns on and shuts off about every couple of minutes. Any ideasa?
Most likely problem is the exhaust is plugged. Lint build up and eventually restricted the humid exhaust air.
To test for this locate the exhaust vent where it exits the house. With the dryer running feel for the air flow. It should be similar to the flow you feel from hair dryer.
Second test is to light load the dryer setting the heat to high and after several minutes of operation open the door and confirm the clothes are hot to the touch.
Hot clothes and no air flow for ever to dry!!
  1. Remove hose from wall connection. Confirm vent hose not plugged by running dryer. Very dusty process. If no air step 2.
  2. Remove vent hose from back of dryer. Confirm air flow from dryer. Very dusty process. No air step 3.
  3. Service dryer blower likely plugged with lint. If dryer basket turns I would assume blower is also turning connected by drive belt. The blockage internal to dryer.
  4. So if not 1,2 or 3 than blocked vent hose to the outside . Suggest using a vacuum hose to carefully try to retrieve lint build up. Lets hope that it is not a roof vent because it would really suck trying to pull the blockage out. And unless your Santa roof tops are dangerous places to play.
  5. Well at least at this point we know why the clothes are not getting dry. What ever you do do not breach the venting in the walls. Moisture will build up along with the lint and create havic with mold!!!
  6. Call your husband
26044146-iw0uppkrtuaby0cw3enjxd1j-2-5.jpg Not to sure about the leaf blower, Might work?
Dryer Vent Cleaning Quick Easy Trick
Jan 08, 2016 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer keeps stopping cycle
The most common cause of the error is lack of airflow. Check the exhaust output and see if it is restricted, you may have to check the venting in the building and unhook the dryer from it to check and see. If it runs unhooked from the exhaust system then it is a venting issue. IT could also be plugged lint screen, loose fan motor or obstructed fan. If it is not any of those then it is the thermal sensor or thermostat that is bad.
Jul 09, 2013 | Miele Dryers
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
My dryer does not heat. Clothes do not dry.
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose. If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Dec 06, 2010 | Kenmore Dryers
Takes 3 cycles to dry clothes
This is a potentially deadly scenario. If the clothes are warm but just not getting dry, there is a problem with air flow - specifically - the lack thereof. The chance of fire is a real concern.
Make sure the lint baffle / trap is clear. This should be checked / cleared after each drying cycle. Most folks know about this, but I included it just in case this is your first dryer.
If the the baffle / trap looks clear, the exhaust tubing of the dryer is suspect. Many installations consist of the flexible / expandable hose. This hose may have become crushed during the running of the dryer, reducing air flow. Locate the hose and pull the dryer away from the wall to inspect, expand or replace the hose as needed. If an old installation, it is very possible that the hose has become clogged with lint build up over the years. The hose should be replaced in this case.
If at all possible, use aluminum expandable dryer duct. It is less likely to collect lint as quickly as the flex plastic style.
If the clothes are not warm or hot, the heat source (electric heating element or gas flame - depending on type) has a problem. Either of these problems should probably be referred to a pro for proper repair.
Jan 20, 2010 | Kenmore Dryers
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
The dryer is overheating.
Fresh air is drawn in past the heating element into the drum out through the lint trap and exhausted outside the building. If the dryer protection systems are operating properly they will sense the over temperature and shut off power to the heating element via thermal switches. This will cause the elements to cycle on and off and reduce the drying ability.
Things to check.
First make sure you fill the dryer only about half full of clothes, usually the dryer capacity is around twice the washer capacity for this reason.
Second, make sure your lint trap and exhaust duct work from inside the dryer all the way outside are free from lint build-up. You should clean or have the dryer duct work cleaned either every year or two depending on the amount of drying you do.
Third, suspect is the dryer thermostat stuck in the on position. You may be able to test your drying temperatures by selecting (cold) fluff air setting, then the low setting and so on to see if that's working properly. If you can read electrical drawings, usually the manufacturer includes a diagram inside the control panel for service techs to refer to. You can test the flow of air out of the dryer by removing the hose from the exhaust, it should have a good volume of air when the dryer is running. After hooking the hose back to the exhaust duct work, check outside the building for the same air flow and don't forget to clean any outside flaps that keep the rodents out of the duct work.
Keep your lint low by not over drying your clothes. You will cut down on lint and prolong the life of your clothes! Dryers are one of the simplist appliances to figure out, unless they have complicated electronic control panels.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Not drying clothes completely
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow.
Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater.
It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element.
Other possibilities:
Blown out heater - requires replacement
There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning.
If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate.
Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.
Jul 19, 2009 | Estate Dryers
My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Feb 21, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Dryer
The secret to great dryer performance is air flow. Fresh air must enter from the rear of the dryer through the vents and exit through the exhaust. If this flow is compromised it will increase the dry times. The length and condition of your exhaust vent would be the first place to check. Some of the industry have said that if you use dryer sheets the lint filter could be plugged from the wax used in dryer sheets. This idea is not industry wide. If your lint filter apears to have a white color across the mesh, then it is plugged. Warm soapy water and a soft brush will clear your filter. Your dryer was designed to have a certain amount of cubic feet per minute of air flow. Anything that changes that will effect your drying cycle time. Lint build up inside the dryer can also restrict air flow. A back up of hot air will cause the thermostats to cycle off prematurely.It can also cause the the drive motor to over heat, the thermal overloads on the drive motor will kick out and keep the dryer from restarting again until the motor cools off. A loud buzzing noise or a lack to start or both can mean a bad motor.
Sep 22, 2008 | Maytag LSE7806A Top Load Stacked...
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
146 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
