Question about Frigidaire FRT18S6J Top Freezer Refrigerator
I have a frigidaire top freezer. the model is frt18s6j. there is water collecting underneath the crisper drawers.
    Problem Solver:
  • 8 Answers
Make sure the seals on your doors are in good condition. Also check that the fridge is turned to a correct temperature and not too warm. Also ensure that the freezer is performing as expected as poor performance may indicate a drop in the appliances capacity. Check that the back of the fridge has reasonable airflow around it as this can restrict capacity also.
Posted on Mar 13, 2011
Model # ET22DK, water is collecting underneath the crisper drawers.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Whirlpool Refrigerators
Water collects at the bottom underneath the crisper drawers Model # P/N 241543915
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Frigidaire 20.5 Cu. Ft. Top-Mount...
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
I have water collecting at the bottom of the frig under the crisper drawers. It appears to be coming from the freezer. Do I need to defrost and if so how?
It shouldnt need to be defrosted if it is a frost free refer. It sounds like your defrost drain line is clogged and backing up. Check the drain pan underneath refer.
Oct 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water collects at the bottom of the unit underneath the crispers and needs to sponged out every week or so.
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 24, 2010 | Frigidaire GLRT216TA Top Freezer...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water pools under the crisper drawers and looks as if it is draining from the upper freezer down the side of the refrig door, looks like the little hole under the crisper is clogged with rust?? It is a old...
Mine clogs with a soft fungus mat but rust actually sounds better. I run a stiff wire like an unwound hanger into the hole and open it up so the water will drain onto the tray made to collect this water underneath the fridge. Last time I left the wire in place with a long handle and I haven't had water to mess with for many months now. My hole is between the two crisper drawers and when I get into either of them the wire gets a jiggle and I guess that's all it takes to keep the hole clear so the water can drain like it's supposed to.
Otherwise the fungus builds and builds until it sluffs off as a wad and plugs up the works on a regular basis. Too funky for sure.
Jun 21, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Frigidaire FRT18S6J Top Freezer Refrigerator Logo
118 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
