Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Reddy heater R50B --- plug into 110V , spark plug fires continuously, motor does not start but seems to spin freely by hand, plenty of fuel, cleaned photo cell (also by-passed photo but same results)
  • jpfitt Mar 13, 2011
    the first expert didn't read the problem description--- when you plug the heater in the spark plug begins to spark, but the fan doesn't come on. What controls the fan? Is the photo sensor involved only after the flame is lit?
    I by-passed the photo sensor but nothing different happened.
  • 5,603 Answers
These heaters have a lockout that has to be reset. If it doesn't see the flame with a sensor, it kills the pump so as to not pump unburned fuel. The sensor and lockout are in one piece as I recall and has a reset button to re-arm it. Your user manual should show this.
Posted on Mar 13, 2011
    Genius:
  • 1,114 Answers
Things I would check in order:
when you plug it in and it "hums" does the fan rotate? if so does the ignitor fire? remove the top cover and look at the fuel nozzle while running, should be an even cone shaped spray pattern. if no spark remove the ignition lead and hold it close to the end of the ignitor, check for spark there, you should be able to slowly pull it farther away fron the ignitor up to about an inch(use insulated pliers) cause if it bites you it stings, if not the ignition module is going bad. if you have a weak fuel spray remove the back plastic cover on the motor and there are filters inside, then remove the six bolts that hold the inside of the filter housing to the motor. inside is your pump, should be a round carbon rotor and four pump vanes. make sure that there is no damage and also check the plastic coupler that the rotor attaches to the motor armature. if everything looks good re-install the pump and filter housing. like in the previous post check the fuel hose and the hose running from the pump to the fuel nozzle for cracks. you need a pressure gauge that is in 1psi. increments and install it in the port on the back of the pump housing that does not have a hole in it. run the heater and check the pressure, it should be around 5psi but the pressure setting should be listed on the side of the heater. to adjust the pressure turn the plug with the hole in it until the pressure setting is correct. as long as everything checks out the problem is usually solved. depending on the model heater there are photocells(flame sensors), high temo sensors, and thermostats that could hinder the function of the heater. these are just some basic troubleshooting steps for forced air kerosene heaters
Posted on Mar 12, 2011
  • Charles Huckeba
    Charles Huckeba Mar 12, 2011
    Here is the website where you can purchase any parts for your model if needed, http://www.reddyparts.com/
  • Charles Huckeba
    Charles Huckeba Mar 13, 2011
    There are not many things that can go wrong with a heater, check to see if the fuse on the indignation control assembly, if it is good then you will want to test the ignition control, if it is good, then you will want to check the start/run capacitor, if this is bad then replace the part. If it is good, then you will check the motor to see if it is getting power, and for a 60,000 btu motor you should be getting
    5.57-6.81 as a reading. If all of these things check out, then your heater should be working.
Heater will not start. When plugged in, it just produces a buzzing sound. Kerosene is full, and fuses are good. What can I do?
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Does the blower motor start when you plug it in/turn it on? It may take around 5 seconds if your heater has a HSI(hot surface igniter). If it does you need to check the igniter and the fuel flow. Either way, remove the top of the heater. You will be able to see the fan, igniter, and fuel nozzle. Turn the fan by hand to see if it turns freely. If it does, watch out for the fan and turn the heater on. Look for the igniter to start sparking (spark plug type) or glowing (HSI type). Next, use a flashlight to look for fuel spraying from the nozzle. If fuel isn't spraying, try cleaning the fuel nozzle and check the fuel filter. Watch out for the HSI, if you have one, they are very brittle and easily broken. If you still don't have fuel flow after cleaning the nozzle and the fuel filter, you may have an air pressure problem. Let me know and I will tell you how to check it. Don't forget to rate the answer if it works.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Will the fan on the reddy heater not run if the ignighter is bad? When i plug it in the fan doesn't run.Do i need to replace the motor?
The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Reddy heater has spark but no fuel to ignite it?
the black hose that goes to the back hooks to a pump on back of motor take screws off back and filter clean when back together turn fan by hand and should hear a small vacum at back of motor , not pluged in clean nozzel
Apr 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a reddy heater model R70 that wont ignite.
I have the same problem. What is the matter with it? It seems like it will not pump fuel.
Dec 31, 2008 | Reddy Heater R70 Portable Forced Air Space...
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
165 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Outback Jack
Outback Jack
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
