Question about Garmin GPS
I own the Garmin 200 and it went dead yesterday and will not turn on
  • 1 more comment
  • greene30850 Mar 13, 2011
    There is no reset button on the bottom of my Garmin, but I did try to rest the lock button on the top of the Garmin and then I reconnected it to a power source but nothing happened.
    I found it and it worked Thank You so very much
    Ezrahite was right on time and resolved the problem that I was having with my Garmin 200 right away.
  • 2,632 Answers
Welcome to Fixya. If your Garmin 200 won't turn on can you please do the steps below and it might fix the issue.
1. Disconnect the Nuvi from external power
2. Press the RESET button on the bottom of the unit. You can use a Paper clip to press it.
3. Connect the nuvi to a power source
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 12, 2011
  • 1 more comment
  • Rofel Lantican
    Rofel Lantican Mar 13, 2011
    You're using Garmin 200 right? The one on the image below?
    The reset button is on the back refer to the image below.
    You can also refer to the Garmin 200 Manual. The step i've provided is the step on how to fix the system that won't turn on. If all else fails check the warranty of your Garmon unit and if possible for warranty replacement or repair it would be better. All details is on the manual.
    If you have questions you can put a reply under this answer. Thanks
  • Rofel Lantican
    If it works you can rate me so i can help others like you. I believe that infront of you there is a Thumb where in you can rate me as i resolved you issue . It is on my first answer across my name. Thanks
  • Rofel Lantican
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200w while charging the battery it started to flash and went dead. It will not respond.
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I hope that helps.
___________________
Sep 04, 2009 | Garmin nuvi 200W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Apr 22, 2009 | Garmin nuvi® 200 Car GPS Receiver
Garmin nuvi 200 frozen screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Mar 16, 2009 | Sony NV-U71T GPS Receiver
Garmin nuvi 200 appears dead
hit the reset button on the bottom
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
Blank screen. Not working at all.
Try to turn it on while it is plugged into the charger and see if it works. if not, you might need to update your software using this website: www8.garmin.com/support/collection.jsp?product=010-00401-20
Oct 22, 2008 | Garmin StreetPilot c340 GPS Receiver
No power
I prayed about it, next day it worked!
Aug 03, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 350 GPS, not working
Hello, Here was my problem. I was traveling at 60mph yesterday and my Nuvi 360 dislodged and fell down with a huge impact inside my car. I came home and tried to look for any damage. Unfortunately Nuvi had stopped to continue beyond loading maps screen. I tried rebooting , but the problem persisted. It would take me to reboot screen, but after screen calibration, when it came to loading map screen, again went blank. I tried this and just simple starting by pushing power button several times but to no avail. I called technical support, eho advised me to to just simply connect it to my labtop and leave it that way for 3 to4 hours. Bingo!, in the next 30 mins, I accidentally switched my laptop top off, but Nuvi had started to work all fine.
Aug 30, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
