Question about Panasonic VIERA TC-P54Z1 54 in. Plasma TV
How to connect a panasonic tcp50gt25 tv audio out (opictal) to a pioneer amp.with opitcal. i connect the cable but no sound,any idea for setting,i did the setting for optical on the amp but still no sound
  • 23 Answers
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
Posted on Mar 12, 2011
Unable to get audio from my Panasonic smart tv when I connect my pioneer cv dv171 DVD player with an hdmi cable
Hi Robert, This worked for me on my Samsung TV; using the TV remote, got to TV settings menu, go to Audio, find "external speakers" and enable that.
I hope that works for you.
Jun 26, 2017 | Panasonic Televison & Video
How do I connect a set of Pioneer 6ohm, 50w speakers to a DP42SM?
If the Pioneer speakers are of the active type (built in amplifier), you can connect them to the left an right analog audio outputs of your TV. If the Pioneers are passive speakers, you need to connect them to an amplifier/receiver first and then use an interlink cable to connect amp/receiver to your TV.
Apr 16, 2016 | Pioneer Audio Players & Recorders
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
I HAVE A PANISONIC TCP50GT25 AND A PIONEER VSX509S AMPLIFIER.I HOOKED THE OPTICAL OUT ON MY TV TO THE IN ON THE RECIEVER AND THE IS NOTHING COMING FROM THE RECIEVER.WHAT AM I DOING WRONG...
First, stop guessing and crack the manual.
Is there a D in the model number?
Register and download the manual for the VSX-D509S for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx-d509s.html
Page 21 talks about assigning the optical digital audio inputs.
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical cable is expensive). Yoi COULD skip the TV entirely. Many don
Mar 10, 2011 | Audio Players & Recorders
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
I'm trying to get the xbox working through the home theatre system but I'm still getting the sound from the TV which has intergrated freeview. The Xbox is connected to the TV using an HDMI cable, the home...
you need to hook up the xbox' audio cables to the home theatre systems AUX in port and then have your system set on AUX, and you can leave your xbox' hdmi plugged into the tv, just be sure your on the correct AV chanel.
Dec 24, 2008 | Panasonic Home Theater System System
Panasonic VIERA TC-P54Z1 54 in. Plasma TV Logo
647 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
