Question about Westinghouse Dishwashers
I have a westinghouse SB916 dishwasher - 2 years old. It is not disssolving the powerball.When the cycle is finished the un dissolved powerball is still sitting in the open door. So I re run the cycle putting the powerball in the cutlery holder - sometimes that works sometimes it is still not fully dissolved. I have tried putting it straight into the cutlery holder but it still does not dissolve. Any ideas?
  • 4,323 Answers
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 12, 2011
I have a fairly new Fisher and Paykel double drawer dishwasher. A problem has developed all of a sudden whereby the Finish powerball tablet does not completely dissolve during the cycle (top drawer only),...
The water temperature is not coming up to the required level. The heater might be failing. Will need a technician to fix unless you are very savvy with technical repairs. Have you tried using the detergent powder in the dispenser to find if results are different.
Feb 05, 2014 | Fisher Dishwashers
Westinghouse sb916
check hot water supply. Is the valve open?
Aug 07, 2013 | Dishwashers
Customercare
Generally what type of detergent you use depends on what is recommended for the dishwasher. I am not sure which model of fisher and paykel dishwasher you have. But my opinion is that dish drawer type dishwashers work better with normal Finish powder detergent. It is not designed for tablets. The size of the wash space is small and it works on the principle of short and quick wash cycles. So the powerball is an overkill. Now about the streaking, this could be linked to the powerball but also you need to check if the rinse aid is present in the dispenser and also that you have selected the appropriate meter level for it being dispensed. 0 means no rinse aid and 5 is too much.;
May 01, 2013 | Fisher and Paykel Dishwashers
Our dishes are not getting cleaned. Food particles remain and spots are all over the glassware. The detergent comes out of the holder, but is hardly dissolved and ends up on the bottom of the dishwasher --...
If your sprayer arms are clear, you will want to check these things.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms.
Also, make sure your water temperature is hot enough to dissolve your detergent. It should be 140 degrees.
Finally, make sure your detergent is fresh. If it is several months old, it might have become affected by humidity and will not dissolve.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 14, 2011 | GE Dishwashers
Hi, I have a whirlpool dishwasher and somtimes it doesn't dissolve the powerball. I have lost my manual. I would appreciate your advice
If you can provide the full model no. of your dishwasher then I can try to find a manual.
Not all dishwashers can handle the powerball. One of the reasons for the detergent not dissolving fully is lack of correct water temperature. If you are using hot water connection then make sure the water temperature is hot enough.
If cold water then it is possible the dishwasher heater is not creating the correct temperature.
Let me have the model no. and I can look further into your problem.
Sep 26, 2010 | Dishwashers
Dishwasher one year old more ofter than not tablet will not have dissolved when cycle finished and door open
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 07, 2010 | Bosch Dishwashers
Power balls not disolving
Check what cycle you are using, the different sections of a powerball are designed to dissolve at different stages of the cycle so if the cycle you choose dont have the stage required it aint gonna work correctly. I think Eco and Fast washes affect them.
Hope this might help
Dec 03, 2009 | Microwave Ovens
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
144 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
