Question about Dell Latitude E6500 Laptop
My wireless will not go on - Dell Latitude E6500 Laptop
  • 79 Answers
Trying restarting the computer. It mostly solves the issue.
Also does it have a specific button for this or you just activate it vai Fn + *?
Posted on Mar 12, 2011
    Genius:
  • 1,542 Answers
Hi
Try pressing the FN+F2 keys both at the same time for a couple of seconds
i think that should enable/disable the wireless
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
Can not connect to network
Connecting to a Wireless Network Using Linksys Wireless Manager Article ID: 17673
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
Nov 04, 2010 | Linksys WRT160N Wireless Router
I have a linksys wireless usb card and it is not detecting my secured wireless network after configuring it
We need to know the wireless settings on your wireless access-point/router.
Check if the SSID broadcast is enabled on the wireless access-point. If it is disabled, then you have to manually add the SSID to the wireless adapter and make sure the wireless security such as WEP or WPA keys are correct.
You may also enable SSID broadcast so that the wireless adapter will detect your wireless network.
Also, you may try to change the wireless channel to 6 or 11.
Oct 14, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Jul 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Netgear wireless adapter
In this case can you please tell me what is your wireless router and how may computer do you have so we can check if this is a problem with the wireless router or with the netgear wireless adapter. because if you only have 1 wireless computer so the problem here is with the wireless router we may need to change some wireless settings like the wireless channel .....
Nov 15, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Belikin adapters and a wireless gateway
If your router is not wireless capable you need to add "wireless access point" on your network so that your wireless computers will be able to connect wirelessly to your network. You can buy WAP54G of Linksys or other brand of WAP(wireless access point).
Jul 08, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Dell Inspiron 1520
it'll not fit since your laptop needs an expresscard.
here are the list of the wireless cards that you can get:
Dell Wireless 1390 802.11g Mini Card Wireless Dell Wireless 1490 802.11a/g Mini Card Wireless Dell Wireless 1505 Wireless-N Mini Card Intel Pro/Wireless 3945 802.11 a/b/g Mini Card Wireless Intel 4965AGN Wireless-N Mini Card Dell Wireless 5510 HSDPA ExpressCard34 Dell Wireless 5520 HSDPA Dell Wireless 5720 EVDO or a Linksys Wec600n Wireless-N Expresscard Adapter
Jun 04, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Helo top experts
i assume that your computer can access the internet while hardwired to the wireless-g router. if so, you just need to connect your wireless computer to the wireless signal of the wireless-g router. you just need to scan or view the available networks detected by your wireless computer and select the wireless name (ssid) of your wireless-g router. make sure to enter the correct wireless security (network key) if it's enabled on your router. i hope this'll help you but if you can't still access the internet wirelessly, provide the specific model number of your wireless-g router, specify if you're using a laptop or a wireless desktop, and the brand and model of your wireless card/adapter
May 14, 2008 | Linksys (WRT54GC) Router
Dell Latitude E6500 Laptop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
