Question about Compaq Keyboard
There 3 lights on the right top side of keyboard - one is capital lock -one is number lock- what is the third one? the light is on and I don't know what to hit ti turn it off.. thanks
    Scholar:
  • 74 Answers
The third one is probably Scroll lock. On your keyboard you should see a key labels Scroll Lock or it may be abbreviated. The key may also have the same symbol as the light. You turn Scroll lock on and off the same way as turning Num Lock on and off. Usually involves using the FN key + Scroll Lock.
Posted on Mar 12, 2011
  • 60 Answers
Scroll lock....
How to know when caps lock is on.
There will be a little light top right corner of your keyboard. Over above the numbers on the right side you'll see two indicator lights there's a number lock light and a caps lock light
Dec 08, 2016 | Video Game Consoles & Games
What is the third light for on the upper right hand side of the keyboard? How do you turn it on and off? What is it used for? I know the first one is the Number Lock, the second is for Caps Lock.
Third light is usually the "scroll lock" indicator.
-Activation Button should be on top row, near far right side, on standard keyboard.
Note: Laptop keyboards vary greatly from the standard layout with 'scroll lock' usually activating using an 'alt' or 'brand' (ex. "Apple") key.
Jan 06, 2016 | Computers & Internet
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Compaq Keyboard -- top right hand corner, the light next to the CAP LOCK is lit. What is this for?
Num Lock ----- Cap Lock ---- Scroll Lock
  • Num Lock --- use numeric keypad
  • Cap Lock --- all capital letters
  • Scroll lock --- stop screen from scrolling ( pause screen )
Feb 23, 2011 | Computers & Internet
Hi, How I shall get to know whether Keyboard's capslock numlock or scrolllock hey is on or off on Logitech Cordless MK250??? I am getting big trouble in entering different capital or small character's...
if the corresponding Numlock, Capslock, Scroll lock light are ON, then it says that the corresponding functions are activated...
For example if the Numlock light is ON, then you will be able to use your number pad...
if caps lock light is ON, then you will be able to use the Capital letters...
Dec 10, 2010 | Logitech Wireless Access Duo Optical...
How can I tell if the Capital Lock is on?
Uually a coloured light at top right hand corner of Keyboard
Mar 16, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
What do the activity lights on the keyboard of the Dell Laptop C640 represent?
To the right of the power button and below the Dell AccessDirect button are three lights. These have a lock synbol below them. The first one from left to right is signified by a number 9, this light is turned on when the numberical keypad is enables. The center light is signified by a letter A, it is on when the uppercase letter function (Caps Lock) is enabled. the third one, far right, signified by a down arrow, is on when the scroll lock function is enabled.
The device status lights on the far right side near the front of the laptop case. The top light is the power status light, the middle light is the Hard drive activity light, the bottom light is the status light for power management, battery, AC etc.
Oct 17, 2009 | Dell Latitude C640 Notebook
How do I turn off arrow down light on right hand side of keyboard. IE 1st light #1 for num lock A for capitals. .
The down arrow is the "Scroll Lock" light. Key should be to the left of the lights.
Thanks for using Fixya.
Jun 14, 2009 | Computers & Internet
Compaq Keyboard Logo
3,711 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
