Question about Canon EOS Rebel XSi Digital Camera
I have a Canon Rebel XSI. Lately, when I try to turn it on, nothing happens. I know there's a charged battery -- two, actually, because there's a battery grip. Sometimes it works, sometimes it doesn't. And sometimes the white balance button will flash repeatedly, even when the power is set to off. I've tried it without a lens. I've tried it without the grip. I've cleaned the gold contacts around the lenses and batteries. Any help would be appreciated.
  • 93 Answers
Try replacing the battery. If that not works then go to any service centre and try removing the static charges.
Posted on Mar 12, 2011
My rebel xsi won't turn on. there is nothing. I used it yesterday and it was fine. I changed the battery and still nothing! HELP!
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
Aug 09, 2012 | Canon EOS Rebel XSi Digital Camera
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
I tried to turn my camera on and nothing happens. All doors are shut, battery is charged and works in other camera. Is there anything else I can try at home before sending it in?
The only causes I can think of that aren't "serious" are a faulty memory card door (camera thinks it's open) or faulty battery door...try turning it on while applying light pressure to both doors and also try to inspect the contacts inside the camera with a flashlight. You can put some rubbing alcohol on a Q-Tip and swirl around inside the battery compartment for a good 5 minutes. That worked on my girlfriend's XSi and it never happened again afterward. There was some VERY minor corrosion on the contacts.
Jan 29, 2011 | Canon EOS Rebel XSi Digital Camera
Camera Canon Rebel XSI not recognise flash 430Ex. The shoe looks OK and contacts on Flash the same
Clean the Hot Shoe and make sure there is no sulfur layer or dirt. MOst of the time its happens for Sulfur layer and not proper connection with flash shoe and camera shoe. Make sure all this and let me know. Also make sure the battery of the flash are fully charged and thats turn on mode.
Jan 06, 2011 | Canon Speedlite 430EX TTL Flash
Canon XSi will not turn on
I think flash pcb or main pcb gone dead so its require to change. Take it to canon service centre.
Jul 31, 2010 | Canon EOS Rebel XSi Digital Camera
My Canon Rebel Xsi is constantly saying Busy. I cant take pics. My battery is fully charged, my card is empty. I have purchaced a ultra fast memory card. What can I do? Please help me....Thanks
i JUST had this problem with my EF70-200mm f/2.8 L IS II USM..
i was shocked at the time...but i did this to get it working again
1) turn off and on = doesn't work
2) turned off everything, removed ext. flash, battery compartment, batteries, unmount lens...reseend everything back in, turned on and it went away
Jun 13, 2010 | Canon Digital Rebel XSi Digital Camera
My Canon Rebel XSi screen will not turn on even though the battery is fully charged.
Does it take pictures? If it does, the display may be off, try pressing the DISP button a few times. If not, the camera may need to be reset, the battery may be faulty, or the camera may need to be serviced.
Feb 26, 2010 | Canon EOS Rebel XSi Digital Camera
Busy light comes on when I start the camera
I believe your camera comes with a 90 day manufacturer's warranty. I would goto Canon's website as soon as possible.
I Can Fix It
Mar 13, 2009 | Canon EOS Rebel XSi Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
