Question about Cell Phones
HOW TO CONNECT A 3 WAY CALL - Cell Phones
    Problem Solver:
  • 7 Answers
After you call the first person press the shift button or green phone button on your phone. You will hear a dial tone to dial the other persons number.After you dial the number press the shift or green phone button again to bring you back to the first person you called. You should still hear the phone dialing the other person and when they answer you will have a 3 way call.
Posted on Mar 12, 2011
Where is the diagnostic port located on a 2000 fiat marea
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
Apr 08, 2013 | Cars & Trucks
I want to put 4 batteries together 4x 12v 7AH. and how many volts and AH would that be.
It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
Jul 19, 2011 | Electric Cycling
I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
How to conect 3 phase motor 9 yellow wires from t1 to t9
There is no neutral on 3 phase. They are all power wires. If you try hooking up a 3 phase motor to single phase power it won't work.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
Feb 14, 2010 | Cooper Industries Cooper Wiring 2158V 3...
How to connect devices to 3-way video switch box
Normally on a 3-way video switch box, there should be 4 ports.
1 ports connects the monitor
3 ports connect the 3 computers video output
Mar 19, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
