Question about Mitsubishi WD-52528 52" Television
The image projected by the tv is extremely dark and hard to see with daylight
  • 23 Answers
Your lamp is going out. it will dim for a time before it dies. check online for a replacement lamp
Posted on Mar 12, 2011
JVC HD-52G886 HDTV Television screen is dark
usually it is the lamp this set uses, has it been replaced or is over 2 years old?
Oct 29, 2012 | JVC HD-52G886 52" Rear Projection HDTV
My rca scenium hd50lpw175 has a dark image, everything else works, no lights blink, no strange noises, just a dark image. Is it just the lamp that needs to be replaced?
Yup. What happens is, from the heat of the lamp, it begins to warp and gradually sag in the socket. As such, the light no longer gets projected onto the screen as it should.
It will likely die within a week or so, altogether. You will indeed need a new lamp. Make sure the TV is not knocked while in operation - that can cause your lamp to quite literally break (in two!) on the spot.
Learned that the hard way with my projector, which is built around the same principles as a projection TV.
May 06, 2011 | RCA Televison & Video
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
Oct 16, 2009 | Televison & Video
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a Sony kdf-60wf655 60 in.rear with dark images and por colors
Lamp is cause of dark image in your tv. Lamp indicator will flash when lamp will be dead.
Nov 07, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Dark picture
I removed the back from the tv and cleaned the lamps, mirror and inside of the screen with window cleaner. The image is now clear as the day I bought the tv.
Sep 22, 2008 | Televison & Video
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Lines in the image
The line area CCD problem- a repair/replacement may be possible if you talk to Nikon support
Mar 30, 2007 | Nikon Coolpix S4 Digital Camera
Brightness
You are going to need the assistance of a servicer for this problem,I suggest not to use it until it gets repaired ,shop around for an estimate ,tell them what the symptom is they might tell you about how much it might cost,is hard to tell without measuring some voltages.Be safe and call for help.
Oct 02, 2006 | Panasonic PT-51SX60 51" Rear Projection...
Mitsubishi WD-52528 52" Television Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
