Question about Endless Summer 153100 Open Flame Patio Heater
Can not start pilot light. where is it located?
    Brigadier General:
  • 4,736 Answers
The pilot light is at the top of the heater inside the mantle screen. You will need to disassemble the top of it, to access it.
Posted on Mar 13, 2011
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
How to light pilot light with sealed broiler oven
What make and model is it? I maybe able to help.
Aug 25, 2016 | Kitchen Ranges
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Nepolean fireplace wont come on when switch turned on. pilot works fien
I have a Monarch fireplace (LP). Each year I have to take a can of computer cleaner "air" and spray out the oxygen sensor located near the pilot light. If dust or a spider blocks this oxygen sensor, the unit will NOT turn on. The pilot lights but the rest won't start. You can also contact your local gas company and ask where yours is located on your unit.
Jan 27, 2015 | Napoleon Fireplaces Main Burner Orifice -...
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
How to light the pilot. The pilot went off when I shut the power off during the Irene storm. I cannot locate where to open so I can light the pilot. I have a GE Profile Gas Dryer, Mod.PDSR 610GG8WT
unless this is a very very old dryer,, it will have a glow plug element in it and should light without the need to light a pilot, just try starting it and see if it lights, But it would have to be ages old to need a pilot lit, I'll try and locate that model, But lemme know if it fires up will ya
Sep 11, 2011 | Dryers
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
Im looking for the pilot light
The pilot light is normally located over the just burner box and will have a small door or removable panel to help get to it. The easiest way to find it it to first locate the gas valve. This will be an aluminum block with a few pipes connected to it. It will also have a knob with Off, On, and Pilot written on it. Once you have found the gas valve, look for two small diameter pipes about 1/4" and 1/8" in diameter. Follow these pipes inside the burner area. It will lead to the pilot assembly. Follow the directions on the heater to start your pilot.
Oct 12, 2009 | Cozy Enclosed Front Console Heater 70,000...
Lang gas oven
The thermostat may be faulty for that section of the oven, it checks to make sure there is a pilot flame via a thermostat that turns the gas on. The thermostat that turns the gas on is usually located next to the pilot light.
Sep 14, 2007 | Ovens
Endless Summer 153100 Open Flame Patio Heater Logo
48 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
