Question about Cycling
We've lost the instructions for installing training wheels & I have a couple pieces that I'm not sure where they go. Can you help?
    Master:
  • 403 Answers
What parts do you have left, can you take pics and send to my email. markpltvt86@aol.com. I will be glad to help the little guy get cruising.
Posted on Mar 13, 2011
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
Why is the locomotive sparking while going on the track
The train gets it's power from the track. the spark, as long as it is small, is normal. it just means the wheels left the track for a second
Nov 10, 2011 | Lionel The Polar Express Train Set
Gday, I have a 04 FXSTB Night Train, could sum1 please tell me how to change the rear brake pads. Do I have to take the wheel off to get to the pads ?? as the caliper & bracket is only 1 peice &...
Remove any saddlebags or anything that hampers your access to the rear brake caliper. Remove the two bolts that hold the caliper onto the brake caliper bracket and lift the caliper off the bracket.
The pads and all anti-rattle parts should stay on the caliper bracket. Pay particular attention to the way these parts are installed in the bracket. Replace all the old parts with new parts paying attention to how the new parts are put in the bracket. Make sure the rear pad is installed with the fiber side to the rotor, not the metal side. Don't laugh, I've seen it done more times that I care to remember.
Now, you have to get the piston compressed back into the caliper. I used either a large C-clamp or a large pair of slip joint pliers. Protect your paint and finish on your caliper by using rags or a couple pieces of wood or something. Once the piston is fully compressed into the caliper, carefully replace it back on the bracket being careful not to disturb the pads or parts. Install the two bolts and torque them to 25 foot pounds.
Now, slowly press the rear brake pedal repeatedly until you get a full firm pedal. Check the level of the brake fluid in your master cylinder. Add only the proper type of fluid called for on the top of the master cylinder cap. DO NOT MIX THE TYPE OF BRAKE FLUIDS. Check the brakes before riding the bike. Failure to insure proper brake operation prior to riding the bike can cause lose of control of the machine resulting in serious injury or death. Make sure you do this job correctly.
Jun 29, 2011 | 2002 Harley Davidson FXSTB Night Train
I need the assembly instructions for the Circo 70 piece Rescue train set PLEASE!!
Here is the assembly instructions for the Circo 70 piece train set (construction theme). Hope it helps:)36faac6.jpg
Oct 19, 2010 | Kidkraft Circo Construction 70pc. Train...
My kids have run the wheels down to nothing so I have bought replacement wheels...now I can't figure out how to get them on! The instruction manual is no help as it is just pictures, and not of wheel...
To remove the wheels, start by removing the little black piece in the center of the yellow hubcap. There are a couple of snap tabs in this black piece that hold it in place. When you remove it, you'll see the end of a metal rod going through the center of the wheels. Remove the star-looking washer (easier said than done) and pull the wheel off.
If you're just replacing the wheels, I recommend making sure this rod stays in place during the process. If it comes out, a couple white cylinders fall out of place in the motor assembly area. If they do, you'll need to remove the seat and black cover under the seat to access the cylinders and hold them in place while you push the rod back in place.
Good luck.
Sep 26, 2010 | Peg Perego John Deere Turf Tractor
Bell brand bicycle training wheels
hello there:
the training wheels are a simple procedure you will need to take the nuts off the back wheel and place the steel spacer and put over the axle then place the training wheel over the spacer and put the nut on making sure the the training wheels are not too low or too high.... best of luck to you hope the information is helpful
May 29, 2010 | Cycling
Install training wheels
when installing the training wheels, check to see if it is put together in this order ....flat washer, training wheel, flat washer, lock washer, nut. I hope this helps. If you are missing any of these you can find them at any auto parts store, Wal-mart, or hardware store such as Lowe's or Home Depot. (Be sure to take the traing wheel and nut to make sure you have the right size)
Dec 27, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
What is the shorter metal piece of training wheel
http://www.ehow.com/video_4974885_put-training-wheels-bike.html This might help.
Aug 19, 2009 | Cycling
Brush cleaning, wheel thump
rchu is exactly right. No need for a complicated disassembly. If you have never pulled off those end bearings/caps, the hair may be very impacted, but removing it should solve the problem. The instructions will tell you by color (yellow for mine) which pieces come off for cleaning. Be sure to remove all such pieces. If the fit seems tight, it's probably because a lot of stuff got stuck in there. Be gentle but firm, and things the should come off will come off. Once you've cleaned all the pieces, the thumping should be gone.
Nov 14, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Cycling Logo
77 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
