Question about Orion HCCA-D2400 Car Audio Amplifier
My orion hcca d2400 amp is in protect mode and i cant get it out of it. It clicks on and trys to turn on the green light (power) then the red protect light blinks then the esp indicator blinks and starts all over again with the power light and just keeps repeating this cycle. Ive heard about a bitwriter or something that can trouble shoot these amps but they are expensive. please help
  • 7 Answers
SOURCE: orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Posted on Sep 18, 2009
blackberries
  • 80 Answers
SOURCE: orion hcca 250 and jensen 600watts amplifiers
i would reccommed at least 2 farad!
Posted on Feb 27, 2009
  • 506 Answers
SOURCE: i have a orion hcca-d1200 and it keeps shutting
Possibly a shorted output transistor. If it was the power supply you would be blowing fuses, which I assume you aren't.
Posted on Dec 22, 2009
trainrick
  • 22 Answers
SOURCE: my orion hcca d2400 is shutting off and on at
this may be called clipping.......not enough power to the amp, too small of a power wire, or the speakers may be too small
Posted on Apr 25, 2010
kenw392
  • 2226 Answers
SOURCE: I have a orion d2400
chances are it is going to have to be repaired.
Posted on Jan 20, 2011
Schematic for orion HCCA-D2400
The schematic or service manual doesn't appear to be available online. You may have to contact Orion. Verify the REM input to the amp. It should be 12V when the car is on and 0V when the car is off.
Jan 15, 2014 | Orion HCCA-D2400 Car Audio Amplifier
My orion hcca d2400 is shutting off and on at times when vol is loud why??
Apr 24, 2010 | Orion HCCA-D2400 Car Audio Amplifier
My amp keeps going into some safe mode and red light blinks and stops base to my sub. I have it hooked up to 1 15.4 Orion HCCA.
The "safe mode" on your amp usually kicks in for two reasons - the ohm load on the sub is too low for the amp (presenting a "short" to the amp), or it's going into thermal protection because the amp is too hot. From your description, it sounds like there's a short in the wire, the sub's ohm load is too low, or the sub is partially blown.
If you have another sub or speaker, connect it to the amp's output and see if the amp still goes into protection mode. If the amp goes into protection with a known-good speaker, then there may be something wrong with the amp's power supplies. If the amp works properly with another speaker or sub, then I would check the sub that's causing it to short out.
You may also want to check whether or not the amp is over heating by just touching the amp when it goes into protection. If it's just warm, that should be ok - if it's hot, then it might be working too hard. In this case, you may need to check the input voltage (12-14VDC) and the size of the power and ground cables. If your ground isn't properly connected, it can cause weird problems like over heating, shorts, erratic behavior, etc...
Mar 04, 2010 | Orion HCCA-D5000 Car Audio Amplifier
Directed d2400 red and green lights on constant and no output...whats the solution
ok ive had an orion amp do this before. oiron is made by directed audio now so its the same style amp. after i checked the ground, power, subs to make sure they were good and not shorted together, i came to the conclusion the amp was bad. its in protect mode right now so check everything with a multimeter and make sure everythings good. if all is ok the amp may be bad. good luck.
Dec 23, 2009 | Directed 2400d Car Audio Amplifier
When i adjust the controls on my orion2400 hcca
your amp is shorting internaly most likely from be handled rough the only thing i recemond is replaceing it cause it will fail completly it just a matter of time & it could be a fire hazared in you car
Jun 03, 2009 | Orion HCCA-D2400 Car Audio Amplifier
Yellow light start blinking
do you have a power cap, if not your amps not getting the power it
wants what size wire you running should be 2gage
Apr 29, 2009 | Orion HCCA-D2400 Car Audio Amplifier
Yellow light starts blinking when i raise gain control
this might be because the subs might not be able to handle the power that the amp is putting out. this could also be a peak power light. try turning the volume down on the head unit, and see if it still does it.
Orion HCCA-D2400 Car Audio Amplifier Logo
248 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
