Question about KitchenAid KSM150PS Artisan Series Stand Mixer
I took out the two black flat screws on the side of my KitchenAid mixer and out sprung a spring and magnet. When I replacter them my mixer won't start...
  • 4,340 Answers
It sounds like you removed the brushes, look in the hole and determine the orientation of the carbon brush( what you describe as magnet). Rotated 90 degrees may keep motor from running...
Posted on Mar 12, 2011
  • 2 more comments
  • spdn4fun Jul 29, 2011
    Very helpful...thank you! I did the same thing, obviously without reading around on how to repair, and then it wouldn't turn on. I thought really messed it up and would have to get a new one. Nope, did exactly was was suggested and it worked! There's a little notch inside the hole and the carbon brush (magnet looking thing) is actually cut to fit the notch. Once I lined them up, it worked! Thanks so much!!
  • caj21259
    caj21259 Feb 09, 2013
    Thank you so much for the solution. I won't do that again
  • Barbie Sep 15, 2013
    Thank you!!!! I will never do this again either!!!! You two helped me out a lot!!!
  • Jack Hidde
    Jack Hidde Mar 05, 2014
    I did the same and it's still not working. I even replaced the Brush with new ones. Any suggestions on what to try next?.
How do I repair the speed settings It only goes on fast speed.
The screws are roughly 8 turns in from fully out when starting to set the speed. On the lowest speed 13 revolutions of the planetary in 15 seconds is a good speed.
Dec 05, 2012 | KitchenAid Artisan Series Stand Mixer -...
Wont turn on
Try checking the brushes located on the side of the mixer ,theres one on each side under a black plastic screw make sure you remember how you took them out,put them back same place.
Oct 23, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Mixer won't start. Fell on its side and on/off lever was bent. Straightened and it now moves back and forth as it did before. I took out the two black screws at the top which hold in magnets on...
Get A Copy of the Repair Parts List from Kitchenaid.com
Make sure the Speed Lever and and the Speed Link are in place
and operating smoothly. The two Large black screws you are referring to
are the Motor Brushes Caps. The Carbon Brushes are keyed and
designed to be inserted into the Motor Housing but one way. If you
insert them in wrong, they will not make contact with the Motor Coils
and you mixer will never run.
All you have to do now is adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 24, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
Well, I was attempting to replace my speed lever. In the process I removed the back cap (electrical circuit board) and the two screws on the side (flat, springs with magnets attached). After I replaced...
Hello Lora,
I understand that you took you speed lever out to replace it and you took the brushes out of each side of the unit. The reason that the unit will not start is more than like the brushes are not installed the proper direction.
1. Unplug the machine
2. Shine a light in the hole on the hole on the side of the unit. You will notice a notch or a piece sticking out.
3. Take one of the brushes (magnet looking things) put the notch and the cut out in the same corner.
4. Repeat the samething with the other side.
5. Plug in and check and see if it runs
This should solve your problem with the brushes. IF you have any more questions about this mixer please post it to this discussion.
THank you for choosing FixYa.com
Justin
Mar 13, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I took the side screw out now it won't turn on.
The brushes aren't contacting the commutator on the motor. Remove both screws, insert a small phillips screwdriver into the exposed springs and simply push down until you feel resistance. That should fix it.
Oct 21, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Jan 29, 2010 | Food Mixers
Took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Took brushes out to check and cannot get kitchenaid mixer to work.
Look at the brush from the side.. The surface that rides on the armature is curved> One leg is longer than the other leg. The long leg is the trailing and the short is the leading edge. Looking at the cooper end of the motor you can tell which way the motor rotates by the traces the brushes make. The leading edge will be on the clean side and the trailing edge is the side that is smeared black.on tthe copper. The long leg of the curve on each brush goes on the smearch side of those copper bars the brush rides on. Both brushes. Looking in the hole of the brush holders you will see what I mean. When you put the brushes in, you must make sure they are up against the copper and the springs are holding them down evenly.. You can lift the brush carefully and let it go to make sure it is working freely. Now, see if you can put an attachment on and turn it by hand. I'm not sure you will be able to so don't bend anything or hurt yourself.. Put the brush caps back on, remove the attachment and plug the mixer in.. Attachments off, fingers clear, turn it on. Does it run? If not, tap the mixer on its side with your hand.. Make sure the switch is on high. Tap it several times if need be. This is to straighten up the brushes to where the springs want them. When the motor starts turning, slight taps help. Keep it going until it picks up speed and let run for five minutes to seat the brushes. Let me know if it still won't run. I'll be watching for a comment from you.
Oct 26, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Springs on side under black screw, came out
Or, more helpfully, take them back out.  Look in the hole, and you will notice that when you look through, the hole turns square. At the end the square, there is a little tab / square in one corner.  It is generally *not* the same on both sides. You'll notice that the end of the piece you took out (the part that looks like a magnet) has one corner cut off -- so it's a rectangular box with one of the corners gone.  Line up the missing corner of the piece you took out with the corner that has the little tab -- this allows the piece to get past the tab and be fully inserted.  Reminder: check both sides, because they're not the same. And now, more helpfully, if you're curious, check out flea markets and get a broken Kitchenaid to take apart for $20 or so. Don't mess with your nice one. : )
Apr 24, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Mixer stopped working after I took the black screws on the side out. Thought that I put it back in right with the springs. Maybe I didn't. What could have happened? Thanks Nancy
The brushes must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
3,335 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
