Hobart AM14-253 Free-standing Dishwasher
Problem for Hobart AM14-253 Free-standing Dishwasher
Hobart AM-14 dishwasher
By chacocanyon on Aug 01, 2008
We have a weird problem. The dishwasher won't fill as high as it normally does and consequently does not wash dishes properly. The little floater thingy that tells the dishwasher when to stop filling is functioning, but seemingly at the wrong height....? I've never noted where the height is supposed to be, but it seems to be 6 inches below where it should be. I can't find a diagram to support any hypotheses. Help?
Solution #1
posted on Sep 30, 2008
Not Rated)
doobo67
Rank: Wiz
Rating: 84%, 19 votes
it has a time out function once float is up is your water pressure correct. if to low it will first few cycles be low but after the will get to correct level and that is to the top of grey plastic drain pipe it cannot or should not be higher then the Gray drain pipe top, it overflows out that any extra rinse goes down it. check the o-ring on bottom of that grey pipe you could be leaking out the drain in between loads you come back and half the water is gone.
Was this helpful?
Yes
No
Popular Solutions for Hobart AM14-253 Free-standing
Questions and Unsolved Problems for Hobart AM14-253 Free-standing
Do you recommend Hobart AM14-253 Free-standing Dishwasher?
Answer
Answer
How much water does my machine use per load. I cant find my manual. Hobart AM15
Answer
Hi, My dish washer water doesn't get hot anymore. I;ve stripped the heating element and put a... (More)
Answer
Low Heat on booster unit Psi gauge not in green zone
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
