Hdmi not working - Televison & Video
    Master:
  • 403 Answers
Is the tv channel on the hdmi channel your using, should be numbered next to port on tv
Posted on Mar 12, 2011
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
Panasonic LG plasma no audio on hdmi 1
HDMI cord may be faulty. Try the cord that works on the port that doesn't If it works then the HDMI cord is bad. If it doesn't work then the HDMI port may be bad on the TV.
Dec 29, 2012 | LG 42PC3RA 42 in. HD-Ready Plasma TV
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
I have a 37" Insignia L37Q tv with 4 HDMI inputs. Only HDMI 1 works properly. If I hook up an HDMI device to any of the other HDMI ports I get one of the following: 1. No signal 2. Not supported 3....
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 16, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Jun 06, 2009 | Toshiba 26HF85 26 in. Television
My HDMI port no longer works
have you retried booting the hdmi cable by turning all products off remove hdmi cable then turn products on then re insert hdmi cable
Mar 11, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
