Question about Mordaunt Short Avant 907W Subwoofer Speaker
My Mordaunt-Short 907W has developed a bad habit of humming and buzzing. This low-pitched droning sound gets louder as time passes. The problem has gotten bad enough that I just don't use the sub any more. I have had it in my home theater for several years, but this problem has only recently developed. What could the problem be?
5 Suggested Answers
sanjin
  • 56 Answers
SOURCE: subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Posted on Mar 10, 2008
Ganx
  • 113 Answers
SOURCE: i Have a buzzing mordaunt short avant 916i cone
Hiya, its the cone. The former is touching the magnet inside. Realignment is really tricky and dont know many people who can do that so you may either have to live with it or see if someone can recone it in your area.
Best of luck
Posted on Jul 15, 2009
  • 232 Answers
SOURCE: 309i sub not working
hi ,
2 things to do
1 - the power amp has fail and will need to be looked at
2- your amp could have a sub output faillure
Posted on Jul 15, 2010
rommelalilin
  • 2178 Answers
SOURCE: Hi my name is Ben. I have a Mordaunt Short home
It can be repaired. A transistor shorted and possibly some resistors burned open as well. This is due to an overload causing the transistor to drive hard creating heat and eventually shorting out. The transistor needs to be isolated, removed, and replaced as well as the resistors.
Posted on Nov 12, 2010
Testimonial: "Thank you very much I will follow you advice through. Your quick response is very much appreciated!"
Refrigerator has developed a low buzz or hum. Do I need to be concerned?
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator, LFHT1817LW1, is buzzing or humming. With modern, high efficiency compressors you may hear a high pitched humming or pulsating sound. Additionally, if you have an icemaker equipped inside of your refrigerator the water valve may produce a buzzing noise as the valve opens to fill the icemaker with water. I hope this has been helpful. -Matt
Oct 15, 2014 | Frigidaire Refrigerators
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
Low pitched humming
When it makes the noise and you able to do this try turning to the right and to the left. If the noise changes or goes away than your on the right track with a bad wheel bearing.
Dec 27, 2012 | 1998 Pontiac Grand Prix
Hi my name is Ben. I have a Mordaunt Short home theatre system which is probably 6 yo but has had very little use. On standby mode, the 309W sub started to make a buzzing sound with intermittent louder...
Nov 12, 2010 | Mordaunt Short 309W Subwoofer
Humming/droning noise, front driver side.
guess i should make this so you can rate the solution ... thanks
Feb 01, 2009 | 1999 Volkswagen Golf
1998 Ford Mondeo GLX, loud humming sound, front driver side.
Most likely it's a wheel bearing going out.., If you turn to the right, or the left when driving the noise will change pitch. Been there done that.....
Feb 01, 2009 | 1998 Ford Escort
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
Mordaunt Short Avant 907W Subwoofer Speaker Logo
188 people viewed this question
Top Mordaunt Short Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
rhodesworks
Are you a Mordaunt Short Audio Player and Recorder Expert? Answer questions, earn points and help others
