Question about Lowrance HDS-7 6.4 in. GPS Receiver
Where do Install the side scan sonar transducer on a 44' fiberglass boat with twin screws? If I transom mount as shown, will I have interference from the wheels? 2nd. IF I do mount on transome, it's approx a 40' run of wire up and thru to the flying bridge where the display wil be? Do they offer extension cables and if so will the longer run havew any affect on the performance?
  • 4,340 Answers
I suspect that the long run will not affect the performance, and I suspect that extensions are available, check with Lowrance.
Consider a through hull mount, if you are worried about prop wash interferenace... Also, I would like the depth to be read closer to mid ship..... Hate to pull be vessel. but that is how you would do it...
Posted on Mar 12, 2011
  • captainalvog Mar 14, 2011
    Thx Doc, the transducer is a separtate component from the side scan transducer. It's configuration is such that I have never seen a Thru hull fitting that will allow just a cable from the transducer "thru the hull. It appears to have to be either transome mounted or "keel" mounted. Keel, I think would give the best results? But I still have to get teh cable thru the hull. Thx for trying tho!
Could you please tell me the transom angle on a 2006 lund,SSV 14,need to know,to mount a transducer correctly.thanks
Don't over think this. Mount your transducer so it will set parallel to the lake bottom when the boat is in the water. If your off by a degree or two it will not affect your sonar performance. The human eye can measure differences in angle down to about 1/10th of an inch. "Eyeball it" and you will be good to go.
Dec 19, 2014 | Boating
How do i disable the depth sonar
There is a selection either under sonar options or the main menu sonar tab that allows you to turn the sonar off. Article Details
here is a link to Lowrance to download your users manual in a PDF format.
Oct 17, 2014 | Lowrance Elite-4 DSI Combo with 455/800kHz...
Y cant i mount my structure scan transducer on the bottom of the boat
This is what the manual says:
The StructureScan transducer can be mounted on the transom,
jackplate, step or directly to your boat's hull.
When mounting it directly to the hull, you must purchase a high-
quality, marine grade above- or below-waterline sealant/adhesive
compound.
Jul 20, 2014 | Lowrance LSS-2 Structure Scan HD Black Box...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
93 bayliner 2252 transom angle
you might want to post this in the boat section
Jul 27, 2012 | Cars & Trucks
Sonar is working erratically. Loses bottom and flashes. Anything to do other than replace the transducer?
I have a very similar problem. Unfortunately my boating season is over until next May. I found I was at software rev 2.30 and should be at 3.40 Some of the software updates were to resolve sounder problems.
Jul 04, 2011 | Garmin Gpsmap 498, External Antenna With...
I have lowrance 337 c gps combo, I have a lund baron i/o aluminun boat. When the boat is running i get alot of interference on the screen. I tried running the power cord for the graph direct to the...
You can use a thru-hull transducer but a transom mount transducer will always interference with all of that water and alot of air bubbles moving under it at high speeds.
Jul 16, 2009 | Boating
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
Lowrance HDS-7 6.4 in. GPS Receiver Logo
303 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
