Question about Car Audio & Video
My radio in my 2000 Impala comes on, but the speakers has no sound. It goes in and out. Now there is nothing. I checked the radio fuse and i know the speakers work. Does this mean my radio has a loose wire or short? If, so how do i fix it myself?
  • 23 Answers
Generally there are more than one fuse for car radios. if there is an outboard amplifier which several of these models have then there is a fuse for that as well. The amp would be located in the underside of the package tray in the trunk. The fuse should be located in the engine compartment fuse panel. If it was fading in and out though that could point to a more serious problem, either a solder joint problem or some water damage. check the fuse location in your manual for the amplifier fuse.
Posted on Mar 12, 2011
Volvo 2000 s 80 Radio/CD player screen lights up, but nothing comes out of speakers. Occasionally, I will here a speaker pop. How 2 diagnose? Water on floor. Possible damaged amp?
doesnt sound good ..water there
could be bad earths
amp may have a fuse
speakers need to be tested manually
these links may have wiring layouts etc
VOLVO Car Radio Stereo
Audio Wiring Diagram Autoradio connector wire...
Volvo Radio Wiring Diagram
Oct 11, 2016 | 2000 Volvo S80
Got in my 09 Impala after work & no display or sound from my radio. Went to the gas station stopped opened the door no door chime? I have no clue what the problem is, the dash indicators work?
It seems to me you should check your fuses, they burn all the time. There inside your car most of the times under or near the steering wheel somewhere in that erea
Sep 23, 2016 | 2009 Chevrolet Impala
Rear speakers have no sound
No speakers are not fused.. It is most likely a speaker wire that has gone to ground so they would have to be traced to each speaker to see if you can find the short
Jan 10, 2014 | 2007 Toyota Camry
Recently put factory radio back in truck radio comes on but no sound from speakers is not working only hear speakers when I run radio directly to speaker it sounds like static but no audio
You need to re-trace your wiring and check your fuses! It's going to be one or the other? Or your Radio is defective!
Try testing the Radio straight from the car battery (or another charged 12 volt battery) using small alligator clips to see if it works, with a good speaker hooked up to it.
(A Speaker you know works, not one out of the car!)
This way you'll know if the Radio is good? If the Radio works, fuses are good and wiring is correct, than you have bad speakers!
Hope this helps! Please rate my help, if I was of any assistance to you at all! Thanks!
Martie
Sep 15, 2011 | Escalade 2000 Stereo Radio Install Dash...
Where r the fuses for the speakers
RADIO FUSE IS SPEAKER FUSE.IF GETTING NO SOUND RADIO SOUND CHECK SPEAKERS FADE AND BALANCE CONTROLS.
Oct 08, 2010 | 2000 Mercedes-Benz S-Class
No sound comes out of the speakers when raido is on
set it to radio or put in a cd and put it on cd mode and try playing if there is no sound then check radio fuse in the fuse box to see if th eamp fuse is blown.
Apr 11, 2010 | 2000 GMC Yukon Denali
Radio works (tuner, volume control, cd) but no sound
If your radio looks to be working and no sound, open trunk and mounted underneath the deck lid you will see your amp or sound booster. It should have two plugs that plug into it. Unplug the one with two orange wires and with the car switch turned on, check to see if the two orange wires have power on them. If they don't get ready to take out the rear interior and underneath the rear carpet almost at the front seat you will see a big plastic sleeve full of wires on the passenger side. Inside this sleeve there will be one orange wire branching into two orange wires, check to see if it is corroded. That would be where I start.
Aug 29, 2009 | 2004 Chevrolet Impala
No sound for door chimes or radio
Is the radio stock? If so have you tried getting a different OEM radio?
Jun 07, 2009 | 2004 Chevrolet Impala
2002 Chevy Impala Radio Doesn't Work
Check the radio fuse? Box is drivers side end of dash(drivers door open)or pass side end of dash(passenger door open)
police models have a connection for the speakers (passenger floorboard under floor mat) to connect the speakers to the police radios.
If they had the speakers connected to their radios,they may have unhooked them and not connected them back to the radio.
The wires are brown,grey,blue and light blue.All into a blue connector.
Apr 30, 2009 | 2002 Chevrolet Impala
Car Audio & Video Logo
211 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
