Question about Cisco AIR-AP1121G-A-K9 802.11g/b Wireless Access Point
AP loses IP - Cisco AIR-AP1121G-A-K9 802.11g/b Wireless Access Point
  • 79 Answers
What exactly do you mean by AP loses IP?
Are you saying the AP access point is no more able to get IP from DHCP server?
or the AP is no more able to provide IP to the connecting users?
Posted on Mar 12, 2011
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
I have dsl modem routeur dhcp enabled with ap wifi ssid = x everything ok ip 192.168.1.1 i have tew 637ap n upgrader wire connected on dsl modem router with static ip 192.168.1.20 ssid = y everythings...
You may be trying to connect through a G or B device to your N router. Verify that there are no serious obstructions or that the pc is not underneath something or enclosed. Metal near the pc can cause the signal to lose strength. Not having a wireless N card or adapter can also cause this.
Also if you are trying to connect through ethernet cable verify that windows is being assigned an automatic ip address, if it is static in windows change it to automatic.
Apr 29, 2011 | Trendnet TEW-638APB 300Mbps Wireless N...
@annj2...... How to do full factory setting on wap-1001,level-1 products 11g outdoor wireless AP/bridge hence to remove administrator password?
  1. Start the web browser (make sure you disable the proxy) and type 192.168.1.20 (The default IP of outdoor AP ip Address) in the Address field. Press Enter.
In Management section, you can Backup/Restore Setting, Firmware Upgrade and Reboot the system in following pages.
  1. Backup the current settings to a file - Click on the "Backup" button, system will prompt you where to save the backup file. You can choose the directory to save your configuration file.
  2. Restore settings from a backup file - Here you can restore the configuration file from where you previous saved.
  3. Restore factory default setting - Be very carefully before restore system back to default since you will lose all current settings immediately.
If you act the function, the ip address will restore the establishing value situation.
192.168.1.20 in the IP Address field and 255.255.255.0 in the Subnet Mask field.
Hope this helps!
Dec 19, 2010 | Computers & Internet
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
May 01, 2009 | Compex NetPassage 28G Wireless Router...
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
My wireless access point SMC
Thank you cgahongayire.
Follow these steps to retrieve the wireless key:
1) Connect a computer wired directly to your accesspoint.
2) Assign a static IP on the computer with the range of 192.168.2.x (x is any number from 3-253).
3) If it prompts you for a user name and a password, user name is admin and password is smcadmin and click Login.
4) Select Advanced Setup. It will give you the window for the access point.
5) Select Security under Radio Interface 2. You can see which security is set on your AP. If it is set as WPA, the shared key is your network key. If WEP, the network key across the selected key is your password.
Take note that these instructions are if the IP settings of the Wireless AP have not been changed. If it is, you have to ask what is the IP first.
May 06, 2008 | SMC (SMC2555W-AG UK) 802.11a, 802.11g/b...
Lost contact between PCs connected via AP
Set all the PC's to have a manual IP rather then using the DHCP from the router.
Also set the Gateway and Preferred DNS on the network cards to the routers IP (IE 192.168.0.1)
Apr 18, 2008 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
Cisco AIR-AP1121G-A-K9 802.11g/b Wireless Access Point Logo
211 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
