Question about GE 7-5290 Clock Radio
I have a GE model 7-5290 kitchen radio. The 10 memory locations for setting channels are full, and I need to overwrite them with new channels. The directions say "You can overwrite preset station numbers by pressing RECALL to select the number and then press SET to confirm selection". This makes no sense, as these steps do not work. Do you know how to change preset channels?
SOURCE: Setting Time
Unplug all power (battery too) and wait a few minutes. Plug in power and 12:00 will start to flash. Press "set" and then release it. Now press any of the two buttons to the right of "set". One will increase time the other will decrease time. Hold the button down and time changes faster. Do not press any button when you have obtained the correct time for at least a minute or so.
Posted on Sep 25, 2007
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
Sorry, the above link is bad. Here is the correct link. You will need Abobe Acrobat Reader, as it is a .pdf file. You will also have to use the magnifier feature to view the fine print.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Posted on Feb 16, 2008
SOURCE: Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
Posted on Nov 17, 2009
  • 11 Answers
SOURCE: set the time? ge model #75350.
Download the manual here:
http://www.devicemanuals.com/guide/CD%20Player/RCA/RCA-75350-User-Manual-==TVRJMk1UZ3k=.html
Or open the battery compartment on the right side and press the clock button, >> or << to set time, and press clock button again to save.
Posted on Jan 09, 2010
jyackle5
  • 8197 Answers
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Apr 29, 2010
Oven on lock but door open and wont shut to use
Sounds like the self cleaning latch might be in the locked position. The latch may have gone bad. I've seen this hapen on lots of GE models. You didn't post the full model number but it looks like RepairClinic may be out of stock.
Try Appliance Parts Pros. Be sure to search with the full model number. It should be located on the front leg just open the bottom drawer.
http://www.appliancepartspros.com/ge-latch-service-kit-wb14k10009-ap5669079.html
Good Luck,
John
Feb 29, 2016 | GE Profile Spectra JGBP90 Gas Kitchen...
Mother board diagram ge cb radio
If the radio is blowing fuses then you are correct in that the protection diode may be burnt. the diode should be black and it should be located near the DC power connector. You should be able to replace it with a 1N4007 Diode.
Mar 16, 2014 | General Electric Radio Communications
Came home to find HDD full and camera recording stopped with monitor saying No Signal. Checked and HDD is formatted though overwrite doesn't seem to be working yet the box for it is ticked. All cameras...
Adjust your settings to continue recording when the hard drive gets full. If 'Overwrite when full' is enabled, the system should start overwriting the oldest data when new data is recorded. Note that these are two different settings: 1) Continue recording (or do not stop recording) when disk is full and 2) Overwrite when full is enabled.
Hope this helps.
Oct 10, 2013 | Televison & Video
Need user manual
Hi David,
I take it that you require a user munual for your GE 3-5908 CB Radio.
If this is correct, then try this: join yahoo group Specific to your radio Make/Model, and apart from lots of useful info you may be able to download manuals, diagrams and such for your radio if available, and all this is free.
Give it a try and I hope you get the info you require.
Cheers,
Peter
Mar 11, 2013 | General Electric Ge Help 3-5908 Full Power...
How to set memory
Here is a specific example. To store
BBC's evening frequency to North America, 5975 kilohertz, into
memory 32, do the following:
1. Press 5975
2. Immediately press the FREQU./METER button
3. Press 3 2
4. Immediately press the STORE button. If the display
flashes, it means that a frequency is already stored into
this memory. To overwrite it, immediately press STORE
again. If you do not want to overwrite it, start over and
use a different memory.
In case you need further settings here is the link for the user manual.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Grundig YB 400PE AM/FM/SW Radio
I need instructions on how to program frequencies into 10 band coverage bc60xlt
There are two versions of the BC60XLT. The BC60XLT (two digit display) and the BC60XLT-1 (full display). Both of these cover 10 bands, but the two digit display model has 10 channels where the full display version has 30 channels.
The owners manual for each is listed below:
http://www.uniden.com/pdf/BC60XLTom.pdf
http://www.uniden.com/pdf/BC60XLT-1om.pdf
If you need additional help, send a reply with what assistance you need. Good luck!
Feb 24, 2010 | Uniden BC60XLT-1 Handheld Scanner
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you clear all channels so i can put the channels that i want in it
There is no need to clear the scanner before reprogramming. When you enter a new frequency it will automatically overwrite the old frequency. To clear unwanted frequencies you can program "0.0" into any channel to clear it, or simply use the LOCKOUT feature to prevent the scanner from stopping on a channel.
Sep 13, 2009 | Uniden BC350C Base Scanner
Radio Reset on PPT
The Battery Pack:KEBT-071-B was memory depleted. Just Try using Alkaline Batteries and test again, if the test results OK, Memory Discharge de Battery Pack Full Discharge and them complete the charge Cycle Again until the Memory Charge error disapear, or optional Buy a new Battery Pack.
Jun 12, 2009 | Motorola T8500 Two Way Radio
How do i reprogram model ge 2-9267a
pull out the plastic tab that holds the piece of paper with the names of the people you speed dial. the instructions are under there.  pick up handset - ignore dial tone or dial tone going away - press "memory store" button - dial the number - press one of the eight buttons for location - hang up phone. that's it - your new number overwrites any old number that was in there. (then write the name of person on the piece of paper.)
Apr 18, 2009 | GE Lands Phones
GE 7-5290 Clock Radio Logo
42 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
