Question about E-Flite Rc Power 32 Brushless Outrunner Motor 770kv 60a
When I plug my new Eflight 32 motor into the battery I get a constant beeping sound and the motor will not initialize. It was working until I unpluged it after binding the controller to my hand held controller. Any help much appreciated
    Filmmaker:
    Uploaded 5 video answers.
  • 13 Answers
Check your TX throtle stick is completly down. ESC beep if they detect signal from throtle channel on start.
Other cause could be you plug ESC in wrong channel in your RX
Posted on Mar 12, 2011
Well my battery of my mustang wint down and i had to chage the battery and my drivers window when it goes up it bouces bacj down to a 1/5 down and i want to know how to restore it.
NOTICE: Make sure no obstructions are present in the window system when carrying out this procedure.
NOTE: A battery disconnect does not require this procedure to be carried out unless the battery was disconnected while the window was operating.
NOTE: Excessive bounce-back (bounce-back that occurs with no obstructions present) may indicate a non-initialized window motor.
NOTE: Carry-out the de-initialization of the motor before initializing the motor.
NOTE: The motor will only operate in the 9-16 volt range. If the voltage drops below 9 volts, the window will not function correctly or may stop moving. If the voltage drops below 9 volts while the motor is operating, the motor will become de-initialized and will need to be initialized.
NOTE: The front window motors must be initialized whenever: a new window regulator and motor is installed, a new window glass is installed, a glass top run removal and installation or when carrying out any operation in which grease or lubricants are applied to the window system. A new front window motor is in a proportional up/down mode until initialized.
NOTE: The convertible rear window motors do NOT need to be initialized as they do not have one-touch up or one-touch down functions.
NOTE: All front window components (window glass, window regulator, window motor and glass top run) must be installed/tightened and adjusted to specification before carrying out this procedure.
NOTE: If this procedure is only partially completed, the front window motor remains non-initialized and only the proportional up/down functions operate. A non-initialized window motor may allow one-touch down operation, but does NOT allow one-touch up operation.
De-initialization then re-initialization
The motor can be de-initialized in 2 ways:
Disconnect the battery cable from the battery while the window is operating.
Remove the window motor fuse while the window is operating.
After the motor has been de-initialized, the initialization procedure must be carried out.
Make sure there are no obstructions present in the window system when carrying out this procedure. The door MUST be closed during this procedure (for convertibles, the top and quarter glass must be in the closed and up position), in order for the door window motor to initialize.
The windows must be in the full open position for this procedure to operate correctly.
Press and hold the window control switch in the UP position at the second detent until the window glass stalls into the glass top run for at least 2 seconds.
Once the top run is reached, hold the window control switch in the DOWN position at the second detent until the window glass stalls at the bottom of its travel for at least 2 seconds.
Cycle the window glass an additional 5 times to set the window soft stop for the down position.
Test for correct window operation by carrying one-touch up feature.
Good luck, if for any reason you can't give four thumbs up, please ask for more information. Thanks!
Apr 11, 2011 | 2005 Ford Mustang
Flashing code C:32:11
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Jun 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Dear Sirs: I have a Weiser keyless locke
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
Pride "Celebrity XL Deluxe" 4-wheeled Mobiltiy Scooter
Sounds like your motor brake is out. Usually the discolor on the brake indicates it has overheated.
Apr 12, 2009 | Pride Value Line Revo Scooter 3 Wheel
My driver side window does not auto roll up anymore. How do I fix it?
Window may not be initialized. Follow this proceedure
Window Motor Initialization adobe.gif Printable View (96 KB) NOTICE: Make sure no obstructions are present in the window system when carrying out this procedure.
De-initialization
  1. The motor can be de-initialized in 2 ways:
    • Disconnect the battery cable from the battery while the window is operating.
    • Remove the window motor fuse while the window is operating.
  1. After the motor has been de-initialized, the initialization procedure must be carried out.
Initialization
NOTICE: Make sure there are no obstructions present in the window system when carrying out this procedure.
NOTE: The door MUST be closed during this procedure (for convertibles, the top and quarter glass must be in the closed and up position), in order for the door window motor to initialize.
NOTE: The windows must be in the full open position for this procedure to operate correctly.
  1. Press and hold the window control switch in the UP position at the second detent until the window glass stalls into the glass top run for at least 2 seconds.
  1. Once the top run is reached, hold the window control switch in the DOWN position at the second detent until the window glass stalls at the bottom of its travel for at least 2 seconds.
  1. Cycle the window glass an additional 5 times to set the window soft stop for the down position.
  1. Test for correct window operation by carrying one-touch up feature.
Mar 06, 2009 | 2006 Ford Mustang
Bad vibration,constant beeping on brand new unit
Did the machine work befor the spellcheck was installed? If so look inside the T/W for forgien objects that interfear with the carrier.
DICKYO
Oct 16, 2008 | Nakajima AE-740 Typewriter
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
E-Flite Rc Power 32 Brushless Outrunner Motor 770kv 60a Logo
198 people viewed this question
Top E-Flite Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an E-Flite Toy Expert? Answer questions, earn points and help others
