Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Got new modem and cant get router ti work - Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
  • lugerhomerep Mar 13, 2011
    its wired but we had bad weather and the modem went out.I have new modem and it works fine but the router doesnt work now
    its a wifi encore router that i use for my son to use his ipod and netflix on his wii.
  • 79 Answers
What exactly is the issue?
Do you want to connect it to laptop via wire cable or Wireless.
For wired it maynot need any configuration but for Wireless it will surely need one.
Posted on Mar 12, 2011
  • Oss279 Mar 13, 2011
    What do you mean by the router. Are you able to browse the internet once you connect it to your computer or not?
2 Suggested Answers
  • 825 Answers
SOURCE: belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Posted on Apr 03, 2010
Testimonial: "Hey there. It took me ages to get around to trying your solution. I was prompted by my old modem dying. Your solutions was perfect."
I reset my modem and now i cant get my wifi back on
If your modem pulled a new or different ip address and you did not reset your router it could be trying to use the old IP address and there would be a conflict. IP addresses usually have a lease of 24 hours, S if your IP was refreshed at noon and you reset your mdem and for sopme reason it obtained a new ip address the router would not be able to connect until noon the following day when it tried to refresh. Rebooting the router should cause it to sync back up with the modem and pull the correct IP address. You may need to log into your router and manually release and renew the IP address even after rebooting your router, I have seen a few routers that would still not pull the new address unless this was done.
My preferred method is to unplug power from the router, then reboot the modem. Only after the modem is synced back up do I plug power back into the router, so far this has seemed to work the best.
Jan 30, 2013 | Smcd3gn-res Wireless Router Cable Modem...
I cant get my router to connect with my new at&t modem
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 03, 2010 | Linksys Wireless-G Broadband Router
No modem or internet lights on my Belkin Router
connect the cable coming out of the modem to the isolated yellow coloured(wan) port of the router....connect another cable between your computer and any one of the grey coloured ports....check for the light status now...if its fine try going online...if not type 192.168.2.1 in internet explore and login ti router setup page(password leave it blank...)if your isp is cable then go to connection type and select dynamic...also go to mac clone and click on "clone"tab once and apply changes...but for this purpose you should connect only the computer from which you got connecton from the ISP..if its a dsl connection select dynamic in connection type, it ll work...after applying remove the power supply to the modem and router by unplugging the power cable wait for 2 minutes and plug it back again...if your modem comes with a battery backup then remove the battery wait for a minute and plug back while the power cable is unplugged...if your modem is embarq or bell canada or bell sympatico or century link, then login to routerpage and click on lan settings and change the lan ip address from 192.168.2.1 to 192.168.5.1. It should work....
Mar 30, 2010 | Belkin (F5D5231-4) Router
Need content for motorola wireless router
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 07, 2009 | Arris Wireless G Broadband Router (wr850g)
I cant get my new G router up and running
It is very easy.
Dec 01, 2009 | Belkin Computers & Internet
I tried everything , i hooked up my new router to my modem and begin to set it up and when it came down to connect to the internet it didn't and it said to reboot my modem and i did and it did nothing and...
firstly, go and reset your router again. Then try to set it up again with your manual. Are you 100% sure that all the settings are correct? If so, enter them and everything should work ok. If not, try contacting your internet provider, if there is any special settings you need for your modem to work with your router.
Oct 15, 2009 | Linksys Wireless-G WRT54G Router
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router problem
Try first to reset the router , since your have a new modem the router should be configure first to work with it, so after resetting the router now just run the setup CD of the router to configure it to work with the new modem that you have.............
Sep 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need your help
can you get online directly to your modem? Is that a new router or working before? If it's a new router you need to configure it first to work with your isp if its working before better check first if you have internet from your modem..
Apr 22, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
44 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
