Keep getting error code E31 - don't know how to fix it
  • 3,051 Answers
Hello there and thank you for choosing fixya
Ok the error code that starts with a 3 always will relate to the pressure system
Turn off the machine and remove back of the unit or the case if necessary then remove any pipes that you see that goes to any the pressure switches and blow down the pipes (they should blow clear and fairly easy into the drum.
Blow gently into the pressure switches and listen for several clicks
Check the pipes from the switches to the pressure chamber are fitted correctly and not holed.
Remove the wires on the switches one at a time and re fit them
Re assemble and try again
If the code reappears then this means that one of your pressure switches are bad and need to be replaced ok
Please keep me posted on how this is going so i can help you determine which switch is causing the problem ok?
Best regards Michael
Posted on Mar 12, 2011
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Electrolux EW1000i Front Load Washer
White westinghouse dryer
Hello Mizar - Thank you for allowing me to assist you. If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 29, 2013 | Electrolux Dryers
E31
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 02, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error Code E31
search for error codes thru Google your MAKE
Sep 21, 2017 | Washing Machines
ERROR CODE E31
Hi and Welcome to Fixya!
E31 simply means - Waste Toner Reservoir Overflow Problem (when the total number of copies is more than 100K sheets). After E31 is displayed, 1000 sheets may be copied before shutdown.
Hope this helps!
Takasashi
Jul 13, 2011 | Kyocera Copystar CS-1620 Black and White...
Error E31 on Bushnell V2
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Good luck.
Feb 28, 2011 | Bushnell Tour V2 Pinseeker Laser...
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
E31 error code
Did a little search and this is what I've found. http://www.fixed4free.com/answers.php?id=30722 Goodluck.
Aug 29, 2006 | Zanussi FJD1666W Front Load Washer
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
